1. TaterMay's Avatar
    Does anyone know what speeds our Note 4s read/write to/from SD. I'm about to order an SD card, and I would like to get something fast, but I don't want to waste money on a faster card than I can actually use.
    10-30-2014 07:32 PM
  2. GtoJon's Avatar
    I have put 2 different Sandisk 64gb class 10 cards in mine & both have had issues. I got a Sandisk 64gb Extreme today that I will try with the new VZ Note 4 replacement when it comes. The Class 10 is about $35 & the Extreme is about $75 .... I would get the Extreme from Amazon!
    Cheers, Jon
    10-30-2014 09:13 PM
  3. TaterMay's Avatar
    Cheers, Jon
    I'm leaning towards the Samsung cards. Not sure if the PRO speeds could be reached by the phone or not. I've seen several people on here saying the phone is the bottleneck, but i haven't seen any actual evidence.
    10-30-2014 09:20 PM
  4. TaterMay's Avatar
    Also, do we already have an internal SD card in the Note 4?
    10-30-2014 09:21 PM
  5. bokehsan's Avatar
    No, that would be the internal memory
    10-30-2014 09:24 PM
  6. bokehsan's Avatar
    None of the current phones support the fast UHS-I speeds, so you won't see those 90MB/s read/write speeds. There's no point in getting a fast card unless you intend to remove it from the phone and use a USB 3.0 card reader to do your transferring.
    CehowardNote7 likes this.
    10-30-2014 09:25 PM
  7. TaterMay's Avatar
    So what is this measuring? I haven't added an SD card yet.
    Attached Thumbnails Note 4 SD Read/Write Speeds-screenshot_2014-10-30-20-38-07.jpg
    10-30-2014 09:39 PM
  8. GtoJon's Avatar
    Verizon & Samsung don't know either ... they are replacing the phone & I like the speed anyway for my GoPro Hero Black, so I may as well try it with my Note 4 first Not going to put it in my existing Note 4, because one of the cards turned to toast & unusable & the other seems like it's going down the same path!
    Cheers, Jon
    10-30-2014 10:02 PM
  9. bokehsan's Avatar
    that's the internal memory, ignore the label
    10-30-2014 10:09 PM
  10. lostsoul2's Avatar
    Note 4 SD Read/Write Speeds-a6d64a55-c0e0-4bd5-bd08-4b8554810d27.png
    thats with the sammy pro
    10-31-2014 02:45 AM
  11. muadib279's Avatar
    What app are you using to do the benchmark. I would like to test my card.
    10-31-2014 07:30 AM
  12. capitaltpt's Avatar
    Looks like A1 SD Bench
    10-31-2014 07:55 AM
  13. muadib279's Avatar
    Thanks so much! !
    10-31-2014 09:14 AM
  14. lostsoul2's Avatar
    sorry.. yes its a-1. I tried that other one major one people use but it doesnt seem to work on my phone at all. like others said.. you will not get 80MB write on phones. From what I have seen 20 or low 20s is about the max. Even though other class 10's should have enough to cover anything on the phone I would like to see how much of a lag there is between one that writes at 20 and one that does at 10. do like a 3-4 min 4K file and see.. who has a 128G and want to test with me? I dont think it just throws it to the sd card.. maybe get on internal ram then processes to sd??..
    10-31-2014 01:08 PM
  15. m3lover1's Avatar
    Internal storage, not memory.
    10-31-2014 01:39 PM
  16. TaterMay's Avatar
    What type of internal storage is it?
    10-31-2014 04:00 PM
  17. TaterMay's Avatar
    Ended up going with the Samsung PRO 64GB card. Delivers today. Will check read/write speeds to see if the phone can actually use the extra speed. Will post results.
    11-01-2014 12:10 PM
  18. TaterMay's Avatar
    Anyone notice what's wrong here?
    Attached Thumbnails Note 4 SD Read/Write Speeds-20141101_125642.jpg
    11-01-2014 02:15 PM
  19. bokehsan's Avatar
    why did you buy a regular sdxc card?
    11-01-2014 02:24 PM
  20. Grovzy1080's Avatar
    Oh that sucks
    Posted via my Sprint Note 4
    11-01-2014 02:26 PM
  21. TaterMay's Avatar
    Spent a bunch of time looking at all the micro sdxc cards on amazon. Finally decided to pull the trigger, and just didn't realize I had clicked on the wrong one. They're refunding though.
    11-02-2014 01:41 AM
  22. TaterMay's Avatar
    Alright, so I got the (correct)SD card in finally. Now I've got a couple of questions.
    First, ExFat is the format I want if I want to be able to transfer files larger than 4GB, correct? If so, will the Note 4 format to this, or must I use my PC?
    Second, now that my SD card is installed, how does the device distribute files to it? Is this done completely manually by me? Or can I tell it which types of files to be stored internally or on the card?
    11-04-2014 07:16 PM
  23. CehowardNote7's Avatar
    Storage is memory, secondary memory.
    11-04-2014 07:24 PM
  1. Is the back of your Note 4 Creaky?
    By ajneuman in forum Samsung Galaxy Note 4
    Last Post: 11-18-2014, 02:14 PM
  2. Replies: 28
    Last Post: 11-10-2014, 06:11 PM
  3. Replies: 3
    Last Post: 11-03-2014, 10:45 AM
  4. Why is At&t charging more for the Note 4 than the other carriers?
    By scottf0624 in forum Samsung Galaxy Note 4
    Last Post: 10-31-2014, 10:06 PM
  5. Note 4 and Moto 360
    By insert_username in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 03:07 PM
