Re: Alarm won't ring in silent
From my smokin' hot Note 4
Yes. The alarm goes off but there is no sound. It shows up on the screen to snooze or dismiss, no sound. I have checked thru all the settings, cleared cache/settings, restarted, still nothing. I've uninstalled several apps still no dice! Gah the trouble shooting continues.Well, my GN4 is playing the alarm sound even if the phone is in Mute mode. If I have an alarm turned on, I would definitely want it to go off, no matter what the phone's sound setting is at (though blocking mode could also work during the hours set to block calls and notifications). Reesh, you're sure the alarm is "on," right? (showing green like the 6:48 alarm in this screenshot) - sorry, I don't mean to insult you, just trying to eliminate all possibilities . . . .
