I am not yet ready to say it is a bad phone or bad battery. I think you're dealing with learning curve issues from returning to Android from iOS.
From your screen shots, what I got out of it was:
--You had your screen on approx 50% of the time measured by that ss. When the screen is on a lot, you're going to eat battery. That's just how it works. You might want to try having it on auto for a while and see if that helps. I have my screen set that low, but I also override with auto most of the time and don't see much of an issue with the battery drain. If I get on for a long time I will go to manual and dial it down, if I think it will help.
--Your system was on WiFi and Location On was also on approx 50% of the time measured. Whatever is wanting Location info constantly is probably your biggest culprit right now.
There were some other issues I can see, but they are relatively minor and I'd address these issues first and see if it clears anything up.
WiFi/GPS on/off: There is nothing wrong with leaving the WiFi and GPS on with this phone, but if you do, you better make sure you manage your app settings properly. If you don't really need them, nothing wrong with turning them off. With my past Galaxy devices, I had those services off unless I needed to use them. When I got the Note 4, I have been leaving them on just to see how battery life is impacted. I do turn off WiFi when I leave the house or the office, just to avoid the WiFi searching drain, but I am leaving GPS turned on pretty much 24/7 right now. I've been impressed with how well the Note 4 manages resources compared to previous Samsung devices.
But you still have to do your part. Things like, make sure Facebook and other apps are only allowed to "check" for things when there is a WiFi connection, or when you're on the app, etc. Make sure you don't have weather widgets or other widgets refreshing their data too often. I have my weather info update every 6 hours, and if I need it more frequent, I update it manually. So check your settings on your apps and make sure you have them set up correctly. Especially that "home beta" app you had listed. That seemed to consume a fair amount of juice compared to the rest of your system.
I have never seen the need for apps like Greenify if you know how to manage your settings properly. The Android OS does a good job by itself of managing RAM and CPU if you take the time to set up your apps properly. JMHO.
