1. maximalife's Avatar
    Whats the difference? When i had my Note 2, i had 4g. I was able to surf the web and use data durning a phonecall. My note 4 has LTE and i dont get that option anymore...i have the sprint version
    11-03-2014 01:42 PM
  2. bassplayrguy's Avatar
    Because you are on sprint. They are working on some spark network.
    11-03-2014 01:48 PM
  3. Almeuit's Avatar
    4g and LTE for Sprint are the same. Unless before you were using 4g Wimax.
    11-03-2014 02:07 PM
  4. skippyg's Avatar
    Newer spark enabled sprint phones have one radio instead of two so calls+data are not available until VoLte rolls out (someome correct me if im wrong) the benefit is that you'll have better coverage due to the ability of accessing 3 bands of LTE vs 1 band. And overtime once Band26 rolls out coverage will be even better. Band 41 is spark speeds (should roll out in markets with the need for capacity first) Band 25 (what single band phones use) will aid in coverage as it was first rolled out.
    11-03-2014 03:15 PM
  1. DROID Turbo vs DROID Maxx - Upgrade or Stay?
    By acole10000 in forum Motorola Droid Turbo
    Last Post: 08-26-2015, 08:52 AM
  2. Turbo Charging vs. Wireless Qi Charging
    By rxgadget in forum Motorola Droid Turbo
    Last Post: 11-08-2014, 08:04 PM
  3. Help me G3 vs Z3V
    By mgindi26 in forum LG G3
    Last Post: 11-04-2014, 10:52 AM
  4. Replies: 2
    Last Post: 11-03-2014, 01:57 PM
  5. Turbo vs Maxx charging speed
    By Snareman in forum Motorola Droid Turbo
    Last Post: 11-03-2014, 05:23 AM
