1. Chetan Jalan's Avatar
    I am facing issue in using facebook.
    1. The app closes automatically in 2 to 5 sec
    2. I am not able to click on my friends profile. the option does not allow me go inside.
    Is there a solution?
    Regards
    11-04-2014 01:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you sure it's the latest version? Try going to the App Manager, select Facebook, then Force Stop and Clear Cache/Data. Now try again.
    11-04-2014 02:12 AM
  3. maximalife's Avatar
    Yea mines does the "click on profile, nothing happens" thing too....might be a Facebook issue...idk
    11-04-2014 06:41 AM
  4. Chetan Jalan's Avatar
    guys still on relief. hv tried every dam thing. pls help
    11-05-2014 07:54 PM
  5. B. Diddy's Avatar
    Try booting into Safe Mode, which will prevent all 3rd party apps from starting initially. Then open Facebook. If it works fine, then some other app (that hasn't been started yet in Safe Mode) is probably interfering with it. You could continue to open apps one by one until Facebook crashes, which should identify the culprit. Safe Mode instructions are here: Access Safe Mode - Samsung Galaxy Note® 4
    11-06-2014 02:13 AM
  6. fragologist's Avatar
    Have you tried going into the app manager and clearing the history and cache. Then uninstall it. Then reinstall from the app store. I've had similar issues with apps before and went through the process I just described and it took care of the issue. Hope you get it fixed.
    I am in the process of making my Note 4 self aware.
    11-06-2014 11:35 AM
  1. Replies: 3
    Last Post: 10-11-2015, 03:25 PM
  2. Replies: 104
    Last Post: 06-11-2015, 06:42 AM
  3. Can anyone help me with some Note 3 issues?
    By jeev9 in forum General Help and How To
    Last Post: 11-04-2014, 04:15 PM
  4. Can I use my phone to make a quest at acmemb?
    By jemerysmith in forum Ask a Question
    Last Post: 11-04-2014, 01:02 AM
