12-15-2018 05:42 PM
191 1234 ...
tools
  1. JCravelle's Avatar
    Unfortunately still not working for me still (Galaxy S5, Android 4.4.4, AT&T). I've tried all of the above fixes, nothing works. Am still not getting text message sound when message app is open and chat string is ongoing, only when the app is closed do I hear a notification sound then, upon opening and reviewing message, should that person keep texting, no sound. I've also tried installing a 3rd party message application from Google Play Store just to test it out, and still have the same problem, no sound with chat/message text string. ANY THOUGHTS APPRECIATED. Thanks! (If / when AT&T updates to Lollipop maybe this will go away ugh.)
    04-04-2015 01:18 PM
  2. Colin Mayr's Avatar
    I found a fix...maybe. I'm running lollipop on a US Cell LG G3. I had the lock screen turned off so as soon as I woke my phone ( The g3 has a 'double tap on the screen to wake' feature) it would go straight to what i had been doing and I didn't have to swipe to unlock or any of that. If that's the case for you, enabling a lock screen again might make your phone give you the notifications you're looking for. It's a pain because I don't want a lock screen, but at least I'm aware of messages coming in again.
    Best.
    04-09-2015 04:11 PM
  3. Nitro211K's Avatar
    As ridiculous as this sounds, I have spent the last 2 days fiddling around and diving through songs and I finally found a fix that worked for me. I have the galaxy s5 through Verizon...go to Settings>>>Applications>>>Messages>>>Notifications>>>Notification Sound. When it pops up to let you pick what sound you want, turn the volume up or down using the button on the side of your phone. I have no idea what made me think of this, but it worked and I finally have sound on my text message notifications. Hope this helps everyone!!
    Hi, Which phone and Carrier did this work on? (I tried this on my Sprint Note 4 Lollipop and no dice on that method).
    nicholberry and Sonia Dunstan like this.
    04-14-2015 10:46 AM
  4. RandylK's Avatar
    I found this forum looking for the cause of my Galaxy S6 personalized contact message tones not working in message+
    While looking for the mute conversation option mentioned earlier I discovered 'Tone' at the bottom.
    Apparently with this app you have to set the message tone in the contact AND message+ conversation thread.
    I hope this helps someone.
    04-16-2015 02:09 AM
  5. misshollywood_1976's Avatar
    I was getting text messages, but my notification sound wasn't working. I had the volume all the way up and the song/ringtone that I picked worked. (Cause I had to play a preview of it before I could select it.) So I knew nothing was wrong with my speaker. The app that I chose for my text messages, for some reason, automatically disabled all notifications on my phone. So I would get text messages, but it wouldn't ring or notify me that I had gotten a one, even though I knew the volume was up and everything worked. To fix, I had to go into my messenger app>>>settings>>>notification settings>>>enable notifications. This fixed the issue for me, I hope this helps some of you.
    04-16-2015 03:37 PM
  6. BobHelms's Avatar
    Newbe. Galaxy S5 Verizon. This issue (no message notification sound) started after the 5.0 Lollipop update. When I decrease the ring volume to mute and later turn it back up to the original setting I lose my message notification sound. I've gone through all the settings in this post, none of them work. When I do a restart the problem goes away. Is there any way to escalate this issue with Google support? TIA for any help.
    04-19-2015 01:31 AM
  7. Marc Vance's Avatar
    GS5, 4.4.4 G900A (ATT)
    Hope this helps everyone.
    I was having the same issue, went through all the fixes, nothing worked........ however, after disabling the "pop-up window" for the stock sms messaging app, I have not have had a problem since. It's a nice feature which I would like to have as a preview, shame......
    Anyone know whether this is an android issue,or a hardware fail??
    (obvoiusly not my phone, but an example...)
    04-21-2015 04:04 PM
  8. peyoung's Avatar
    Hi Everybody. I have a Galaxy Note 4. I too have the issue of the notification alert not sounding if the conversation is open.I had upgraded from a Note 3 which chimed with each incoming message. I thought there would be a simple solution I just hadn't found yet. So I called Samsung customer service. Samsung rep. stated there will NOT be an alert if the conversation is open. "Because if you're looking at the screen you don't need an alert" she said. No solution...no work-around. That's it... just the way it is! SAMSUNG FAIL!
    BTW I loved my Note 3. But the reason I received an upgrade was because of issues it had with hairline cracks appearing all around the bezel. I'm loosing confidence in Samsung!
    lollipopfail likes this.
    04-24-2015 12:39 PM
  9. joker8334's Avatar
    Yea unfortunately this happened on my note 3 when it updated to lollipop. If conversation is open you wont get alert. Now if im active in the convo isnt too big a problem...issue is if i leave convo open and put phone down. Screen locks and turns off but i still wont get alerts bc convo is tecnically "open". Ugh smh
    04-29-2015 07:05 PM
  10. pups3's Avatar
    Thank u, thanku, thank u! I thought I had tried everything. Now i just need to figure out how to be able to connect to my pioneer nex 6000 so i can see my phone screen on it. Anyone have any thoughts? Thanks again!
    05-08-2015 02:21 PM
  11. lollipopfail's Avatar
    Does anyone know of a 3rd party messaging app that still has this response notification ringtone alert feature in open conversations?
    Thanks.
    05-19-2015 08:01 PM
  12. sweetypie31's Avatar
    Thanks.
    Gosms goes off if the conversation is open.
    05-19-2015 09:06 PM
  13. cindygbt's Avatar
    I had the galaxy s6 edge and had the same issue. My boyfriend has the same phone and his works fine.. BUT I have tmobile and he has Verizon. His text message app is Verizon Message.. my is Samsung Message. So I downloaded the Verizon app to my phone and now I get the notifications... not ideal but its a solution.
    05-21-2015 11:55 AM
  14. lollipopfail's Avatar
    It's lollipop - After 2 hours of tech support with Verizon, and the Verizon Tech calling the Samsung Tech, I was told the stock Samsung Messenger App with Lollipop no longer had an alert for open SMS Messenger because "If it is open, it means you are looking at it." <eyeroll> I explained to them that I was waiting for someone the other day after texting them "I'm ready" then I proceeded to put my shoes on, they sat outside my house and texted me 10 times to let me know they were waiting... with no alert. The same issue with the stock Calendar, stock notifications don't work, however if you choose the dropdown choice "email" as the alert it works, but then you have to clear out your email because it is filled with emails of alert notifications.
    After looking at the 3rd party choices (for hours) I installed both SMS KK and Calendar KK, I paid for the Prime version. I love them. I disabled the stock apps afterward. I have no idea what back processes these 2 stock apps were running but since I disabled them my phone's battery life has doubled and everything is running smoother/faster.
    Finally, I am considering disabling the stock Galaxy S5 camera app because the Lollipop update has affected it as well. Autofocus is iffy, as soon as I open it the phone gets hot and the battery drains rapidly. I have 2 other Camera Apps on my phone already and neither of them have performance issues.
    I hope this helps others, and thank you both for helping.
    Vernon27 and cometguy like this.
    05-21-2015 05:18 PM
  15. lollipopfail's Avatar
    I'm just curious if both of your phones run the Lollipop OS (OS = operating system)? My phone is a Verizon Galaxy S5 and the issues only occured after Verizon forced me to update from KitKat to the new Lollipop OS. I declined the update because I was aware of the issues, until Verizon no longer allowed anyone to decline. It is my understanding that some carriers don't have Lollipop yet, but I would think that a phone as new as the GS6 edge would have Lollipop as the original install regardless of the carrier.
    05-21-2015 05:32 PM
  16. Kelly Kearns's Avatar
    Do you mean this one in the Play Store?
    https://play.google.com/store/apps/d...ssaging.vzmsgs
    05-21-2015 07:08 PM
  17. leerandall's Avatar
    That's the one I use. I like it a lot. It has a lot of options, and from what I understand, it will work on non-Verizon devices too. As a matter of fact, I use it on my wi-fi-only Galaxy Tab S tablet too. Works great there as well.
    05-21-2015 07:59 PM
  18. Kelly Kearns's Avatar
    It doesn't have that ugly orange does it? I might look at that.
    05-21-2015 08:34 PM
  19. leerandall's Avatar
    No, no orange.
    Kelly Kearns likes this.
    05-21-2015 09:18 PM
  20. Curtis Miller-Robus's Avatar
    The last day or two I've been having a problem with my notification sound not working when I receive a text. If I turn the phone off then back on it works again. Not really sure if it's a glitch or what. Anyone else having this problem?
    I had this problem on my 2 day old S6. To fix, i went to my gear settings icon > sound notifications > app notifications and selected messages and unblocked. Fixed! Now i get sound when i receive a text.
    06-11-2015 01:13 PM
  21. Prasanth KG's Avatar
    can you tell me exact app name or mention url below...plssss
    06-16-2015 09:57 AM
  22. zeuswsu's Avatar
    It wasn't working for me with the Verizon messages app for some reason. It was driving me crazy, switching to textra fixed the issue for me.
    06-16-2015 12:41 PM
  23. benny2014's Avatar
    I had this happen on my galaxy 5 and now on my note 4
    Idk if it's because of lollipop but everything seemed fine with kitkat
    I have reset the phone per Verizons suggestion because well they don't know what else to do
    I have tried every reset
    tried every tip someone posts online and nothing works
    I'm tired of missing text messages because a new phone isn't performing even though it's the "best one" from Samsung uhhuh!
    If it was it would alert me to text msgs.
    the only way I have found to be alerted of every text msg is to close the text message thread I have going everytime I reply
    so far it works
    PITA yes but so far so good!
    06-17-2015 01:05 PM
  24. Leticia Johnson's Avatar
    Thank you what you mentioned about the Msg+ app w/ VZW was exactly issue. Awesome advice
    06-22-2015 11:12 PM
  25. Eric Hurdle's Avatar
    Hello,
    I had the very same issues. I did all the settings that were suggested by everyone. However, none worked for me. Since l am with Verizon, l just used their message app, and found it was the only solution. Actually, l like the app more then Samsungs. It moved all of my messages over as if nothing changed. I have features that l like, like adding videos in text messages from the phone storage.
    So if you have Verizon Message app, l would suggest using it, or downloading it from the Google Play Store. Apparently it works on all Android devices regardless of if you are with verizon or not. It cant hurt to give it a try.
    I cant post links because l am new. Just download the app at Google Play for Verizon Messaging.
    06-24-2015 01:08 PM
191 1234 ...
  1. How can I make a ZTE N9511 work with Cricket service?
    Last Post: 10-04-2016, 07:41 PM
  2. How do I turn on New episode available notifications?
    By Jeffrey Knox in forum Google Chromecast
    Last Post: 11-10-2014, 10:51 AM
  3. Message app
    By marki86 in forum Moto X (2014)
    Last Post: 11-05-2014, 12:40 PM
  4. Could not connect to device ??????
    Last Post: 11-05-2014, 12:54 AM
  5. Replies: 3
    Last Post: 11-04-2014, 11:32 PM
