12-15-2018 05:42 PM
191 ... 23456 ...
tools
  1. Kristi K's Avatar
    I had the same problem and it drove me nuts! If you turn up your volume you will see an additional setting button. Select it and you will see the volume for your ringtone, media, notifications and system. Somehow my notifications option was turned down. I turned everything back up and it works! Why there is an additional settings button I have no idea!
    12-06-2015 12:11 PM
  2. russell77's Avatar
    I know this thread is old but was having this problem i didn't have a notification sound setting so i went to setting in messages and pushed the volume up button and yhe notification sound turned up not sure how i put it down
    12-13-2015 12:32 PM
  3. TomSmith0719's Avatar
    This worked for me. Thank you!!!
    12-14-2015 08:07 PM
  4. cardsnblues's Avatar
    Sounds like Samsung's customer service rep is just wanting to blow you off. My wife's S4's alert tone on messaging works fine. I've never been able to solve the text alert tone issue. I get one on brand new texts but nothing after. If they think we're always looking at our phone for subsequent texting threads, they're obviously not considering typical users. Next phone will not be a Samsung.
    12-20-2015 11:56 AM
  5. caseyjmc's Avatar
    Here's how I finally fixed my LG G3 Android phone:
    I had been using the Verizon Messages+ app. No notifications worked though all the settings correct.
    Changed to using the Messaging app that came with the LG. Not as fancy, but notifications now work beautifully.
    12-20-2015 05:39 PM
  6. randola1's Avatar
    thank you!!!! i think this will fix my issue
    12-21-2015 04:36 PM
  7. tia1995's Avatar
    For some reason my notifications on my phone randomly stopped working. I managed to fix it by going into Settings- sounds and notifications - App notifications - Scrolled down to 'Messages' and for some reason it said blocked next to messages, so I clicked onto it and turned the block notifications off.
    01-06-2016 01:21 PM
  8. Gobrot's Avatar
    I'll be using Go Sms as suggested,it sends notifications with conversation open. Maybe not as fancy
    as Chomp but I want to know when I get a message! Galaxy S2
    01-18-2016 07:06 AM
  9. Gobrot's Avatar
    Using Go Sms and it seems to work,I'm getting all the notifications now
    01-18-2016 08:34 AM
  10. kerinicole1313's Avatar
    CHECK TO SEE IF POWER SAVE MODE IS ON!
    I was not aware that my power save was on, once I turned that off, my sounds worked as usual.
    01-26-2016 12:15 PM
  11. babbitkop's Avatar
    You are a legend! Thanks so much for solving my problem!
    01-27-2016 10:39 AM
  12. Natalia Trotsay's Avatar
    Thank you so much! I went there and found that my messaging and whatsapp were blocked.
    02-14-2016 06:58 PM
  13. FrancisPingnet's Avatar
    Great, this tip helped me solve my issue!
    Thanks a lot!
    02-17-2016 04:47 AM
  14. crucifiedmusic's Avatar
    I was having the same issue on my LG G3 after the Lollipop (v. 6) upgrade, all of my sounds were working fine except the notifications for text messages. I am using the Verizon Message+ app and had no issues prior to that point. I went through all of the settings and even took it to the Verizon store. What they found (that I foolishly forgot to test) was that the problem was app specific as the sounds worked when using a different app for messaging. So I uninstalled the app (or at least the last update) and re-opened the app, poof, and now the sounds work. Re-installed the latest update for the app and it works as before. Kind of strange that Verizon had not seen this issue by the time I had gotten there, but stuff happens, just glad I was able to resolve it. Hope this helps someone else.
    02-24-2016 03:09 PM
  15. Charles Maou's Avatar
    I have just purchased a Note 4 and have spent 3 days trying to sort this problem of notification sound going off when i get incoming call or message or whatever. Eventually I had the phone flashed, however Samsung told me that they know of this problem with sound notification and it will be fixed on the next update which will be in approximately 3 months time.
    02-27-2016 02:07 AM
  16. nicholberry's Avatar
    THANK YOU - this worked for me. Don't know why I didn't figure it out. Bless you.
    03-24-2016 12:23 PM
  17. nicholberry's Avatar
    YES! Thank you - don't know why I didn't figure it out, but sure glad you did.
    03-24-2016 12:26 PM
  18. Orsonsfatcousin's Avatar
    Doh, so simple, can't believe it didn't occur to me. Thank you.
    03-27-2016 04:07 PM
  19. m_d_m's Avatar
    ReeseyMa, it worked. Amazing it was so buried.
    04-01-2016 03:31 PM
  20. 23JOSH16's Avatar
    Sprint network galaxy s6 notification problems resoled...go setting...app manager...notifications allow...hope it works 4 evry1...it did 4 me...stupid lollipop update
    04-23-2016 02:35 PM
  21. SinCityChris's Avatar
    Had the same problem, this is how I fixed it. (Note 4)
    1. Settings (obvi)
    2.Sounds and Notifications
    3.Application Notifications
    4. Scroll down to the messenger app you use and make sure notifications aren't blocked.
    not sure how mine got set to blocked but I'm glad I finally figured it out. hope this helps
    04-27-2016 10:35 PM
  22. mrgender's Avatar
    i had the same issue with my samsung s4 mini.
    the solution was to unmute in settings -> my device -> sound -> volume -> notifications.
    i don't recall how this setting became muted, although it seemed to start after i had installed a led blinker notification app.
    04-28-2016 01:59 AM
  23. Eagle191's Avatar
    Go to app manager and scroll down to messages. Maybe notifications is blocked. That worked for me
    04-29-2016 03:16 PM
  24. mkufta's Avatar
    I found a fix. So all of a sudden my text messages stopped alerting me and my wife's snap chat stopped giving notification as well. I went to settings > notification > Advanced (top right) > then found Messages app and it was blocked for some reason. Same was with my wife's snap chat. I "allowed" the notifications and it worked.
    05-05-2016 11:42 AM
  25. jepeters55's Avatar
    All sounds work except for text messages. No other apps are downloaded that would interfere with this.
    05-07-2016 10:47 AM
191 ... 23456 ...
  1. How can I make a ZTE N9511 work with Cricket service?
    Last Post: 10-04-2016, 07:41 PM
  2. How do I turn on New episode available notifications?
    By Jeffrey Knox in forum Google Chromecast
    Last Post: 11-10-2014, 10:51 AM
  3. Message app
    By marki86 in forum Moto X (2014)
    Last Post: 11-05-2014, 12:40 PM
  4. Could not connect to device ??????
    Last Post: 11-05-2014, 12:54 AM
  5. Replies: 3
    Last Post: 11-04-2014, 11:32 PM
