1. islandbaby's Avatar
    When i drag down the top menu to toggle the wifi calling feature, its all grayed out and does not toggle on or off. In fact, it just rolls the top menu back up. Has anyone else been having this issue ?
    When i look into the settings, as you can see in the screen shot, the 'turn on' button is grayed out but the 'force stop' button is able to be pushed.
    Im confused. Whats going on here ?
    Attached Thumbnails Sprint Note 4 wifi calling problem-screenshot_2014-11-05-12-47-57.jpg
    11-05-2014 01:13 PM
  2. yo0123yoyo's Avatar
    Go to settings>wifi calling? Works fine for me on Sprint
    11-05-2014 07:38 PM
  3. Gator352's Avatar
    You have to go into settings and set out up. Then it should work!
    11-06-2014 09:30 AM
  4. rlanza1054's Avatar
    Yeah, make sure regular WiFi is on and connected to something, preferably your home network. Then turn on, WiFi Calling.
    Sent from my Nexus 7 using Tapatalk
    11-06-2014 10:24 AM
  1. Note 4 paint chipping
    By Rafal Napierala1 in forum Samsung Galaxy Note 4
    Last Post: 05-19-2015, 12:38 PM
  2. Lg g2 problems with knock on! And call dialpad
    By MATTHEW_ELITE22 in forum Verizon LG G2
    Last Post: 01-12-2015, 02:25 PM
  3. Note 4 CPU 2.65 GHz?
    By UniQue WerkX in forum Samsung Galaxy Note 4
    Last Post: 11-05-2014, 07:23 PM
  4. Since the Note 2 update, why isn't my home screen saving?
    By shaheemie in forum Samsung Galaxy Note 2
    Last Post: 11-05-2014, 01:02 PM
  5. Replies: 0
    Last Post: 11-05-2014, 12:40 PM
