1. phazes's Avatar
    Quick quesiton. Just got the note 4 and I am noticing terrible battery life on it. Within less than an hour I go from 100% to 70% with light use. Anyone else experiencing similar issues? Screenshots attached.T-Mobile Note 4 Battery Issue-qvgumfe.jpg T-Mobile Note 4 Battery Issue-3nscsta.jpg
    11-05-2014 03:31 PM
  2. SpookDroid's Avatar
    Nope, I'm seeing amazing battery life on mine. However, your Screen On Time seems about right. I usually get around 6 on mine. But I certainly don't go from 100 to 70 in an hour, even if streaming from Netflix. Maybe you're playing a CPU-intensive game for an hour?
    11-05-2014 03:34 PM
  3. phazes's Avatar
    Nah this is on my drive to work. I think I have narrowed it down to location just eating the battery life. Not sure how to fix as of yet so I have not been able to keep it on. Trying out battery now without it to see if that's the issue.
    11-05-2014 03:39 PM
  4. kanesmith41's Avatar
    This is on my sprint Galaxy Note 4.
    USMC97
    Attached Thumbnails T-Mobile Note 4 Battery Issue-note4.-46hrs...jpg   T-Mobile Note 4 Battery Issue-note4.-46hrs.jpg
    11-05-2014 03:46 PM
  5. Almeuit's Avatar
    His screen on time is slightly mis-represented since he charged during the cycle.
    @ Phazes - Can you try draining it without charging and then showing us the stats? That will help us get a real idea of what was draining at the time.
    11-05-2014 04:15 PM
  6. Mr973's Avatar
    Did you get the update? That update is for battery....I am on to and here is mine...
    Attached Thumbnails T-Mobile Note 4 Battery Issue-screenshot_2014-11-05-17-09-49.jpg
    11-05-2014 04:15 PM
  7. Mr973's Avatar
    That Lil spike u see cause I was rooting it so maybe that's the reason but...You get the idea no problems over here...
    11-05-2014 04:17 PM
  8. Ntchwaidumela's Avatar
    Quick quesiton. Just got the note 4 and I am noticing terrible battery life on it. Within less than an hour I go from 100% to 70% with light use. Anyone else experiencing similar issues? Screenshots attached.Click image for larger version.
ID:	146117 Click image for larger version.
    Looking at your screenshot and your WIFI signal strength is only at one bar. That could be the problem, as your phone may be searching for a stronger signal, which can use up a lot of battery life.
    gonzoks likes this.
    11-05-2014 06:47 PM
  1. Verizon Note 4 Lock Screen? Weather...
    By sillyrabbitt123 in forum Samsung Galaxy Note 4
    Last Post: 11-26-2015, 04:39 PM
  2. How do I SIM unlock a T-Mobile G3?
    By tpd15 in forum LG G3
    Last Post: 09-21-2015, 02:16 PM
  3. 2-day battery life? I'm not seeing it...
    By lowgman1234 in forum Sony Xperia Z3
    Last Post: 11-07-2014, 01:56 AM
  4. Replies: 0
    Last Post: 11-05-2014, 03:21 PM
  5. Battery Life Help
    By Parafly9 in forum Samsung Galaxy S4
    Last Post: 11-05-2014, 03:07 PM
