1. Kingb1186's Avatar
    I am having problems with note and my home internet. It will go on and off. It will say strong connection but is not working. When I go to Internet settings, it says scanning. I have tried restarting phone, clearing cache, and checking and unckecking scanning button. Ps4 and computer is fine on internet.
    11-06-2014 06:16 AM
  2. rlanza1054's Avatar
    I'm having the same issue.
    I posted a very detailed report.
    Please take the time to read my post.
    Its posted under the 'known issues'.
    I'm not sure if I'm allowed to post to another message. If I can I will update this post.
    I want to contact Samsung and I need to call back Sprint with my findings on some things I tried.
    But for now, I've found the fastest fix was to just do a restart of the phone.
    Don't bother to fiddle with your settings. There is noting wrong with your settings especially if one minute your fine connected to you home network via WiFi from Note 4 and the next you notice that the Note 4 has switched to LTE services via cellular network.
    Since you are the second from my point of view, it usually means there are others like ourselves. And we need to find those affected and band together so that Samsung can see its a REAL problem.
    Let me see about getting link posted.
    Here is the link:
    http://forums.androidcentral.com/sho....php?p=4030763
    So very glad I found your post.
    Thanks
    Rob
    Sent from my Nexus 7 using Tapatalk
    Kingb1186 likes this.
    11-06-2014 11:48 AM
  3. Trinatek's Avatar
    I've previously posted about the issue as well. Adjust the wireless settings on your router, and that could resolve the issue. It has for me.
    11-06-2014 04:11 PM
  4. Kingb1186's Avatar
    Just changed channel on router and seems to be better now.
    11-06-2014 07:10 PM
  5. Moataz Hammous's Avatar
    my wifi goes on & off i have tried another network also this happen i don't know what's solution?
    11-07-2014 12:14 PM
  6. Liquidretro's Avatar
    What settings and channels are you guys using? I have moved to a couple different channels (1 and 6 (Most clear in my area)) and not seeing much of a difference.
    11-07-2014 12:35 PM
  7. Kingb1186's Avatar
    I'm on chanel3
    11-07-2014 02:44 PM
  8. maistro's Avatar
    I'll have to reboot to connect at home and at work. Modifying work router settings is not an option, our corporate office has these on lock-down but reboot works. Will not connect to my Wifi controlled Parrot AR Drone, have to keep my S3 around for that.
    11-07-2014 03:47 PM
  9. dlee1001's Avatar
    I'm also having Wi-Fi issues on my AT&T Note 4 where the phone is connected to the Wi-Fi network but has no Internet access. Turning Wi-Fi off and back on again fixes the problem only temporarily, and forgetting the network and reconnecting has no effect whatsoever, as with clearing the cache and fiddling with other settings that might affect Internet connection. I'm desperately looking for solutions to this problem. Any help is appreciated. I'm not finding that much conclusive evidence online as to why this is happening.
    Is this a known problem with Android 4.4.4 or some kind of software issue that can be fixed in an update? I really hope it's not a hardware-related issue.
    11-11-2014 12:37 AM
  10. Liquidretro's Avatar
    Update on my wifi issues. I am about 99% sure this is a software issue.
    I ended up calling up Verizon business support to make a complaint. We took a while but at the end they submitted a ticket to samsung. So I would enocourage anyone with issues to call up your carriers and get those tickets to Samsung.
    Pretty sure this is a bug with how the IP's are assigned. You might check the IP the phone is being assigned and if it conflicts with something else on your network.
    11-11-2014 10:45 AM
  11. anon9453038's Avatar
    Galaxy Note 4 - wifi won't always connect when I'm out and about...it just grinds away trying to connect. Very annoying.
    I also doesn't ALWAYS automatically connect to my home or office network.
    05-15-2015 10:57 AM
  12. kirksucks's Avatar
    I have a similar post here. WiFi is connected to the router but no Internet.
    Someone in my thread suggested switching to a static IP. I've switched it but wasn't having problems this morning. It's usually when I get home from work.
    05-15-2015 11:54 AM
  13. rjsquiresjr's Avatar
    I have been experiencing the same problem.
    I went as far as to exchange my Xfinity router....and now my phone. I have a "like" new note 4 and I found that the problem was with the Lollipop upgrade.
    05-15-2015 07:54 PM
  14. MedicD's Avatar
    Same issue. Connects but no data. Wife's Note 3 is fine. Tried the static IP thing but no success.
    08-01-2015 11:46 AM
  1. samsung galaxy centura new issues???
    By karmicrules in forum Ask a Question
    Last Post: 11-14-2014, 02:41 PM
  2. Galaxy S4 text message issues
    By Go Faster1 in forum Samsung Galaxy S4
    Last Post: 11-07-2014, 09:50 AM
  3. How to get phone internet by connecting a wire to PC/laptop?
    By acsurfer in forum General Help and How To
    Last Post: 11-06-2014, 01:48 PM
  4. Screen swap aftermath issues?
    Last Post: 11-06-2014, 01:58 AM
  5. Issues
    By itallgood in forum Ask a Question
    Last Post: 11-05-2014, 11:36 PM
