1. yesshh's Avatar
    Anyone have thoughts on extending battery life?
    Left it unplugged overnight for the second charge cycle to be attempted at complete depletion.
    60% at 8 AM and now at 2 PM at 6%.
    Thanks!
    Attached Thumbnails Battery Status-screenshot_2014-11-06-13-54-27.jpg   Battery Status-screenshot_2014-11-06-13-54-31.jpg   Battery Status-screenshot_2014-11-06-13-54-38.jpg
    11-06-2014 02:59 PM
  2. STARGATE's Avatar
    Hello there!
    Saving battery is tricky when you use the phone a lot or have many services working.
    The signal is also another main factor.
    For starters, turn it off, get the battery out, wait a few minutes, put battery back in and turn it on.
    Make sure to disable stuff you really don't need or use.
    You can also choose to stop automatic sync on stuff you can sync manually whenever you want (ie, weather, certain email accounts, etc.).
    You could turn on the auto dimming for the display or set it manually to your liking depending on the time.
    I actually have mine to 100% during the day, at night is about 20% or less.
    I'm pretty sure there'll be more members with other tips.
    iOSConvert2k14 and yesshh like this.
    11-06-2014 03:13 PM
  3. yesshh's Avatar
    Hello there!
    Thanks for those tips! I am not so great with battery management. I look forward to hearing some more tips.
    11-06-2014 04:28 PM
  4. kanesmith41's Avatar
    Sprint Galaxy Note 4.
    USMC97
    Attached Thumbnails Battery Status-note4.-46hrs.jpg   Battery Status-note4.-46hrs...jpg
    11-06-2014 05:39 PM
  1. Replies: 2
    Last Post: 11-06-2014, 06:40 PM
  2. Battery app?
    By maximalife in forum Samsung Galaxy Note 4
    Last Post: 11-06-2014, 02:45 PM
  3. Replies: 1
    Last Post: 11-06-2014, 01:33 PM
  4. Nexus 9 notification/status light
    By NicksGarage in forum Google Nexus 9
    Last Post: 11-06-2014, 12:49 PM
  5. Battery Glitch??
    Last Post: 11-06-2014, 10:10 AM
