1. hopefulfarm's Avatar
    I changed my battery and was booting up and putting on my case and clearly pressed some buttons. What do I do to fix this!??
    It seems to be in some sort of boot loader and downloading something?!
    Attached Thumbnails Help! What did I do & how do I fix?-img_20141106_210345.jpg
    11-06-2014 09:23 PM
  2. Tkbredx's Avatar
    It's in download mode. Happens when you hold volume down and the power button and home.
    Nothings wrong. You can take the battery out then put it back in. Then boot up the normal way.
    11-06-2014 09:33 PM
  3. meyerweb#CB's Avatar
    Just hold the power button down until it shuts off, and then power back up.
    You've entered download mode, which lets you download ROMs and such from a PC. The warning only applies if you're actually in the middle of a download, which you aren't.
    11-06-2014 09:35 PM
  4. hopefulfarm's Avatar
    Thank you! I've been afraid to pull the battery.
    11-06-2014 09:36 PM
  1. How can I erase the videos from my auto back up?
    Last Post: 11-07-2014, 12:32 AM
  2. Replies: 1
    Last Post: 11-07-2014, 12:19 AM
  3. Is there a fixe to blank screen on zeepad?
    Last Post: 11-06-2014, 10:56 PM
  4. Do you have it?
    By arsenictherapper in forum Ask a Question
    Last Post: 11-06-2014, 08:01 PM
