1. tech_fan's Avatar
    I will be getting a Note 4 this time around and I currently have a Note 3.
    I have adjusted settings, add things to S-Note, Action Memo and such. Is there a convenient way that I can transfer these files to the new Note 4 or do, I have to do them manually?
    Thanks
    11-08-2014 10:43 PM
  2. Rukbat's Avatar
    You could connect both phones to a computer at the same time, then copy files over faster. But don't use a USB hub - they usually stop after a few hundred MB of transfer.
    Or use Kies to back up the 3, then use it to sync to the 4. (Settings won't transfer. Some things aren't in normal, transferable files, they're in system databases.)
    tech_fan likes this.
    11-08-2014 11:07 PM
  3. keyzlife's Avatar
    I used Smart Switch app.
    sent from my Samsung GALAXY Note® 4
    11-09-2014 05:42 AM
  4. Connert's Avatar
    If you have your notes synced with your Samsung account they will sync when you log in to your account on the new device.
    Posted via the Android Central App from the beast A.K.A. Note 4.
    11-09-2014 05:53 AM
  5. JimSmith94's Avatar
    Smart Switch transferred most but not all of my stuff. It even got my saved Wifi spots and passwords, which impressed me.
    11-09-2014 04:13 PM
  6. keyzlife's Avatar
    Yes all of the wifi info was worth it in itself.
    11-09-2014 04:14 PM
  1. Replies: 15
    Last Post: 11-10-2014, 03:41 PM
  2. Is a case needed?
    By jerrykur in forum Motorola Droid Turbo
    Last Post: 11-10-2014, 12:31 PM
  3. How to disable the media player from the lock screen?
    By Cryscross in forum Samsung Galaxy S5 Active
    Last Post: 11-08-2014, 10:35 PM
  4. Can't flash TouchWiz back to Cyanogenmodded Galaxy S3 i747?
    By iPhonesAreGarbage in forum Software Development and Hacking
    Last Post: 11-08-2014, 10:25 PM
