1. tonroe's Avatar
    So I'm not sure why this is happening and I think it is effecting my battery life pretty badly.
    I haven't seen this yet on any other screenshots and I'm not sure how to fix it as this is my first android device.
    I would love some tips to stop my phone from constantly using wifi.
    Thanks.
    11-09-2014 04:11 AM
  2. johnkingx's Avatar
    i dont know if this apllies to android but i know ios8 had a problem with wife and battery. the wifi would deplete the battery too much . . . . . . . . but i am guessing maybe your phone is having the same problem. i suggest u keep wifi off unless u are using it
    11-09-2014 05:31 AM
  3. twolastnames's Avatar
    Go to settings menu - wifi, in the wifi settings, hit the menu button on top right, go to advanced. In that menu, there is an option to "keep wifi on during sleep". You can change this to only when plugged into power. Changing helps battery, but not by tons and tons.
    11-09-2014 10:47 AM
  4. macdarwin's Avatar
    Wifi settings - advanced - uncheck always scanning and set keep wifi on to NEVER.
    Helps the battery.
    11-09-2014 10:52 AM
  5. beh's Avatar
    You have over 10 hrs use and 41% battery left. Graphs, charts, etc. don't mean anything if you are getting this kind of battery usage. In my opinion you are making much ado about nothing.
    11-09-2014 11:21 AM
  6. Gator352's Avatar
    Whuuuut? We should get 86 hours of battery with everything turned on! But we are only getting 16 to 24 hours depending on usage!
    That's it. I'm going to jitterbug...
    iOSConvert2k14 likes this.
    11-09-2014 08:17 PM
  7. Gator352's Avatar
    Thanks.
    Seriously, your battery is good.
    11-09-2014 08:18 PM
  8. Javier P's Avatar
    The WiFi bar doesn't mean that it's being used, just that WiFi is On.
    11-09-2014 08:33 PM
  1. Stop Picasa from asking me to sign in
    By AZgl1500 in forum Samsung Galaxy S5
    Last Post: 05-27-2015, 09:54 PM
  2. Replies: 1
    Last Post: 11-09-2014, 05:15 AM
  3. Built in data sleep feature?
    By bkircher in forum Android 5.0 Lollipop
    Last Post: 11-09-2014, 04:03 AM
  4. <SOLVED> Wifi speed drop !
    By Devaaiah Kusha in forum HTC One M7
    Last Post: 11-09-2014, 02:25 AM
  5. Replies: 1
    Last Post: 11-09-2014, 02:15 AM
