03-08-2016 02:06 PM
50 12
tools
  1. Borgettano's Avatar
    ive had the Scandisk 64 in my galaxy s3 and it always said "sd card unexpectedly removed...preparing sd card".....now i have the same card in my Note 4 with same issues.....i had to restart my cell to see all the pics i had on my sd card...and have to do same now....why is this happening??......which sd card should i get to replace the one i have now?...samsung 64 pro??....thanks!
    11-11-2014 03:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Unmount the card in Settings>Storage, remove it, and insert it into your computer's SD reader. Run chkdsk to see if there are any bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html.
    Sandisk is generally pretty reliable--where did you buy yours, and how old is it? If you bought it online from an independent seller, it might be counterfeit--run SD Insight to check. If it's several years old, it might just be failing due to normal wear and tear--SD cards don't last forever.
    If you got the card from a reputable seller and it isn't very old, you might consider contacting Sandisk and seeing if they can replace it.
    11-11-2014 03:50 PM
  3. briankstan's Avatar
    You may have a bad micro SD card, do a google search on it and you'll find lots of cases, it seems there was a bad batch of the 64gb cards when they first cam out specific to the Scandisk 64gb ones. I also had one for my S3 that did that, I sent it to Scandisk and they replaced it for me free of charge. Hope that helps.
    11-11-2014 04:34 PM
  4. Borgettano's Avatar
    I bought it roughly 1 1/2 - 2 years ago off of ebay.....I .just think I'm ready to get a new card because this has been giving me a lot of problem.....is the samsung pro 64 better??
    11-11-2014 04:57 PM
  5. briankstan's Avatar
    I purchased mine about that same time. You should have better luck with a new one. Why not hit them up and get it replaced especially if they will do it for free.
    11-11-2014 06:17 PM
  6. soldier45's Avatar
    Time for a new one...
    11-11-2014 06:47 PM
  7. Borgettano's Avatar
    I bought it from eBay though.....I don't think if I contact the seller that I bought it from, that he would send me a new one......
    11-11-2014 06:59 PM
  8. Preach2k's Avatar
    I am having the same issue but it still looks like the Micro sd is working. I used this sd Card in my GNote3 before bringing it over to my GNote4. Never had an issue with it in my GNote3.. I am Upgrading to the 128GB Microsd.
    Note.notions likes this.
    11-11-2014 07:10 PM
  9. Borgettano's Avatar
    I heard you can only use a 64GB In the Note 4....if i could go with a 128GB,I might as well
    11-11-2014 11:42 PM
  10. Eric Pr's Avatar
    Get a MicroCenter card. They are cheap and very reliable. We use them in all the GoPro cameras in our drone program. I have never had one fail in my phones and my friends phones. Just waiting for a 128 GB version to come out. Based on current pricing, theirs should be around $69.
    Most cards are from the same supplier. You are paying for packaging and advertising on name brand chips.
    11-11-2014 11:49 PM
  11. Preach2k's Avatar
    I turned off my phone took out my SanDisk 64GB put it back in. For safe measure I pulled the battery put it back in put on the back turned it on and so far so good no more Unmounting message while saving to my SD card.
    11-12-2014 12:03 AM
  12. Borgettano's Avatar
    I just tried this,I guess if it still happns,ill just get another card..thanks!
    11-12-2014 12:09 PM
  13. Borgettano's Avatar
    Ok problem still occurring......im going to go buy a new 64GB....what are all the differences between these cards??.....Extreme/Plus/Pro?..... which is the better one?....or basically all the same?
    11-12-2014 03:21 PM
  14. msokad's Avatar
    I had the same issue with my Sandisk 64gb. I purchased a Samsung 64gb and it works like great.
    Borgettano likes this.
    11-12-2014 04:12 PM
  15. Borgettano's Avatar
    Samsung EVO or PRO?
    11-12-2014 04:32 PM
  16. bertsirkin's Avatar
    FWIW, I had all kinds of problems with many different "brand-name" SD cards with my Note 3. I bought a Samsung-branded card and it's worked great (my wife now has that phone). I have a Samsung-branded SD for my Note 4 and so-far-so-good.
    Not sure why the Samsung branded cards seem to work better, but others have commented on this as well.
    11-12-2014 05:45 PM
  17. Borgettano's Avatar
    Any particular samsung? (EVO/PRO).... and 64 gb?
    11-12-2014 09:16 PM
  18. Cavboygt's Avatar
    Love the samsung 32 pro very fast. Wish i bought 128.
    Android Central App Strong Note 4
    11-12-2014 09:46 PM
  19. bertsirkin's Avatar
    I got the Samsung 64GB PRO Class 10 Micro SDXC (MB-MG64DA/AM) - $52 at Amazon.
    11-12-2014 10:26 PM
  20. Borgettano's Avatar
    Hate being a pain in the *** and I appreciate the help.....so I think I'll get the 64gb Samsung PRO.... I read in a different thread that you can't put a 128GB in a Note 4.... Any idea if I can,cause if I can,ill get that instead of the 64gb,unless I can't go that big.....
    11-12-2014 11:17 PM
  21. msokad's Avatar
    EVO
    11-13-2014 03:15 PM
  22. CehowardNote7's Avatar
    You getting bad info!! .
    You can bang a 128gb in the Note 3, so you know it will fly in the Note 4..
    BTW, I never had any problems with 2 Sandisk Ultra 64gb micro sd cards in my Note 3, and my Note 10.1 2014.. I always FORMAT the sd card in the device I am using it in, and I never turn it off when I am doing a write to the sd card..Never a problem.
    Now, I have a Note 4, and I am pushing a Sandisk Ultra 128gb Class 10, it hasn't blinked. I took the Sandisk 64gb Ultra and put that in my Tab Pro 8.4, and it works like a charm..
    I got a zillion movies, music and pics on my Note 4, and still got mucho space left.. However, for the price, right now, the 64gb Class 10s are the best bargains out there.. I got a PNY 64gb Class 10 for my wife S4, for $24 free shipping.. Can't beat that with a stick..
    11-13-2014 03:50 PM
  23. Borgettano's Avatar
    I bought the SanDisk Ultra Pro 64gb and so far no problems...now that I know,i might also get a 128GB....thanks guys!
    11-13-2014 11:20 PM
  24. dpham00's Avatar
    128gb microSDXC most definitely works on the note 4. I am using one now
    Sent from my Verizon Samsung Galaxy Note 4
    11-14-2014 01:18 AM
  25. Borgettano's Avatar
    Which brand??.....maybe ill check amazon and get it
    11-14-2014 03:35 PM
50 12
  1. Replies: 9
    Last Post: 02-09-2016, 10:46 AM
  2. Problem with email always showing unread
    By Bdot-1 in forum Samsung Galaxy Note 4
    Last Post: 11-14-2014, 08:15 AM
  3. Sd card icon
    By Xords in forum Ask a Question
    Last Post: 11-13-2014, 10:43 AM
  4. Replies: 4
    Last Post: 11-12-2014, 10:21 AM
  5. GPS problems
    By kj11 in forum LG G3
    Last Post: 11-11-2014, 10:13 PM
