1. Fa11ou7's Avatar
    So I just picked up my Note 4 and I'm loving it but I keep seeing this weird 'issue?' with the wifi. After connecting to a wifi (and entering the password if necessary) it creates a notification in my drop down menu which says "Connected to 'example_WiFi" Ope... Tap to configure WiFi". I don't really want that notification in my drop down menu and even when I tap it there are not settings for me to configure it just takes me to my WiFi settings. Anyone know what this is all about?
    I'm on Verizon if that matters.
    11-13-2014 04:34 PM
  2. B. Diddy's Avatar
    When it takes you to the wi-fi settings, what happens if you select that network and go through some of its settings, then exit the settings menu? Does that notification still remain?
    11-14-2014 12:53 AM
  3. Fa11ou7's Avatar
    It does go away after I tap it, but it always seems to come back after a time or maybe after I reconnect to the hotspot. I should also point out that when in settings if I tap that WiFi node there isn't anything to configure it's just the basic 'Cancel', 'Edit (password)', or 'Forget".
    11-17-2014 12:25 PM
  4. B. Diddy's Avatar
    Is it with any wi-fi network, or only certain ones?
    11-17-2014 02:06 PM
  5. plumcrazy's Avatar
    seems to be all wifi networks, mine doing the same
    11-17-2014 06:25 PM
  6. rahul.sharma's Avatar
    Same with fb chat heads..how to get rid of these two notifications?
    Posted via Samsung Galaxy Note® 4
    11-17-2014 08:31 PM
  7. ejohnnyk's Avatar
    I just switched from the Sprint N4 to the AT&T N4. Sprint's version did not have this slightly annoying and constant notification. AT&T does. I guess it's carrier specific.
    11-18-2014 02:47 AM
  8. ronb's Avatar
    I believe that that notification is for networks that require a login after connecting. Such as hotels that want you to agree to terms of use before allowing any activity. What triggers it and when it a mystery to me.
    Good luck!
    Ron
    11-18-2014 01:32 PM
  9. rahul.sharma's Avatar
    Its not WiFi login, it just says WiFi connected.
    11-18-2014 01:41 PM
  10. Fa11ou7's Avatar
    Sorry for the late reply, yes it is with any and all wifi networks that it connects to (at least the ones that I have saved and connect to regularly)
    Correct, all of my saved wifi networks secure and unsecure.
    11-25-2014 04:12 PM
  11. myfriend's Avatar
    i have the S5 and this has been bothering me as well. the best way to fix that, as far as i can tell, is to access the advanced wifi settings and uncheck the box for "wi-fi notifications." the only drawback, and it's a minor one to me, is that you will not be notified when a wifi network is available.
    on the (verizon) S5, you get to that box by going to...settings>wifi>3 dots/menu at top right>advanced
    03-03-2015 09:16 PM
  1. Droid Turbo Rebooting When Connected to Apple airport Wifi ?
    By gdflynn1 in forum Motorola Droid Turbo
    Last Post: 10-25-2015, 11:12 AM
  2. how to turn off music that a caller hears instead of a ringtone
    By brucebockman in forum Samsung Galaxy S5
    Last Post: 06-15-2015, 08:30 PM
  3. I got Lollipop and here's how to do it
    By Birk Binnard in forum Google Nexus 5
    Last Post: 11-19-2014, 04:56 PM
  4. Replies: 8
    Last Post: 11-14-2014, 10:28 AM
  5. how to format the sdcard after kitkat upgrade?
    By Adriano Ubriaco in forum Ask a Question
    Last Post: 11-13-2014, 05:15 PM
