On a T-mobile note 4, is it possible to get rid of the s finder and quick connect icons? I never use them and they take a lot of screen estate.
Unrooted and on stock room.
Thanks,
Osho
Thanks,
Osho
1. Download the Xposed Installer APK and install it. (http://dl.xposed.info/latest.apk)^^ Which root method did you use as I too would like to get rid of those 2 features from the drop down menu as well as switch up the neon green WiFi etc. icons at the top. Thanks.
