05-31-2015 10:24 AM
29 12
tools
  1. byrds8's Avatar
    Just picked up a Note 4 today and traded in my Note 3. Anyone else having an issue where signal strength is not as good as the old Note 3? My wife still has the Note 3 and side by side there is like a 10-15dbm difference between the two. I tried a web search and found a couple of mentions about it being that way but not much. Figured I'd ask here to see what the community has to say.
    11-15-2014 06:12 PM
  2. dpham00's Avatar
    Which carrier? Same frequency?
    Sent from my Verizon Samsung Galaxy Note 4
    11-15-2014 07:26 PM
  3. byrds8's Avatar
    Verizon both devices. Ive read i think maybe two things i found on the web about it and they said they tried a few and they were all lower than the note 3. Wondered if anyone here is experiencing the same thing.
    11-15-2014 08:04 PM
  4. Maria Gabriela's Avatar
    i have experience this also with the Verizon version that i bought from best buy. i exchanged it twice and it still weak Signal and 4g goes out many times this not supposed to happen we have Verizon wireless LOL. i tired my same sim on another back up phones i have and they always have 4g but my note 4 has always issues with keeping 4g on + weak Signal.
    i believe the Verizon note 4 have week antennas compare to the AT&t (Korea Made) + Tmobile (Vietnam Made)
    11-15-2014 08:19 PM
  5. byrds8's Avatar
    Maybe they will push an update that will help it out.
    11-15-2014 08:25 PM
  6. exdrinker's Avatar
    My experience is the exact opposite. The Note 4 is a significant improvement to both the 2 and 3. Call quality and reception is night and day difference. I am on Verizon.
    sforsyth01 likes this.
    11-15-2014 10:20 PM
  7. byrds8's Avatar
    Odd that it seems such a wide difference. My quality so far is ok. I havent talked to but a few. But signal strength took a hit
    11-15-2014 11:06 PM
  8. dpham00's Avatar
    The signal when on the same frequency should be very similar on both phones. Now if one phone is on XLTE and one phone is on 700MHz especially indoors then a 10-15dbm difference is about normal. Which is why I asked what frequency before.
    Also, how is it in speed tests? I have had situations where a phone can have a 10dbm worse signal but much faster speeds, due to different frequency . Personally, I prefer much faster speeds even if it means a weaker signal
    11-15-2014 11:44 PM
  9. Andy847's Avatar
    I have the same on mine. I don't have as good a signal as on my N3, but that was on AT&T. When I had my Note 2 on Verizon, getting about the same on my Note 4. So for me it's just worse on Verizon. I get 4 bars usually and no problems with getting LTE and sometimes as low as 1 or 2 bars at home, but still LTE and no dropped calls or internet. I'm just ignoring it like I did on my N2. It just gets me ticked that Verizon advertises these super fast XLTE speeds and better coverage, and I've never noticed that with my N4. I got the same speeds on my Note 2 which wasn't an XLTE phone if I remember right. I'm in a 4GLTE area with XLTE capabilities too. It's fine though, the speeds I get aren't slow.
    It's Verizon though, so since I refuse to pay what AT&T wants for the Note 4, I'm going to see what my Data usage is next month. If it's high, I'm going to either try My Verizon N4 on T-Mobile where I can get more or Unlimited Data for almost the same price as the next Data package up on Verizon, or Sell my Verizon N4 and get a N4 on T-Mobile. Hopefully I will have less data usage next month and will just stay with Verizon.
    11-16-2014 02:51 AM
  10. byrds8's Avatar
    Not sure about the freq. It only says LTE as far as in the status. Other than that is there some way to see what band its riding at any given time? Just ran a speedtest and only get 76ms ping 46.29 down 9.37 up. Bout what I did on the Note 3.
    11-16-2014 06:02 AM
  11. dpham00's Avatar
    With root, you can type *#0011# in the dialer. Or if the speed is above 80mbps down /20mbps up. You can also have an iPhone next to you and look at its band and signal strength compared to the note 4
    11-16-2014 09:10 AM
  12. richmasterflex's Avatar
    What color do you have? I've seen videos of the black note 4 outperforming the white one. Maybe the signal strength is different as well.
    11-16-2014 09:12 AM
  13. trucksmoveamerica#AC's Avatar
    For me it got better, way better from my note 3.
    11-16-2014 09:16 AM
  14. bapte's Avatar
    I had full bars on 4g at my house with my iPhone. Have 2 bars on 4g with the note 4.
    I'm using the Verizon note 4 as well.
    Maria Gabriela likes this.
    11-16-2014 11:09 AM
  15. magnet's Avatar
    Bars means nothing, compare dbm like -80 is better than -100. You can't go by bars of signal.
    11-16-2014 11:27 AM
  16. Netguysc's Avatar
    The opposite for me. My note 3 had terrible reception, the note 4 has great reception. Maybe you should exchange your phone for another 4
    11-16-2014 12:15 PM
  17. bapte's Avatar
    Well my signal strength is -108 32 asu to -102 dbm 38 asu on the note 4. When it hits 3 bars it's usually 102, and 2 bars it's usually 108.
    11-16-2014 12:23 PM
  18. byrds8's Avatar
    I have the black one and I'm not rooted. Never really been into rooting my devices. I guess since I am not getting like 80mbs down im just on lte. There is definitely a dbm difference between the wife's n3 and my n4 not just bars. Ive read somewhere else though exchanging them has done nothing for others having the issue.
    11-16-2014 01:14 PM
  19. dpham00's Avatar
    Either both devices are on different frequencies, or the note 4 is defective. I have had the 6 plus and Note 4 and when on the same frequency, they are pretty close.
    11-16-2014 03:48 PM
  20. byrds8's Avatar
    Just played with both a bit more and watched them while we were out. They are pretty close to the same signal levels it seems. However I do believe the N4 is much more picky about incoming signal than the N3. Its radio must not be quite as sensitive being in some areas of the house my original statement stands. The N3 seems to pick up better.
    11-16-2014 06:02 PM
  21. orporter's Avatar
    I just up-graded to the Verizon Note 4. First impressions. The reception is much stronger on the Note 4. My Note 3 was awful after the upgrade, period. Nothing I did or Verizon tried helped. My reception out of the box, in my house, is -84 dBm, the 3 never came close to this. My Note 2 had this same kind of performance. I am very pleased with this so far. Hope it holds up. I was tired of having to go where T-mobilers went to make calls at my place of work. I like having a smart phone but I also like having a phone that can make calls where it should. Reception is important as these devices advance.
    11-17-2014 10:29 PM
  22. DynoMikeR's Avatar
    Mine was on global out of the box, weak signal also. Had to switch it to LTE manually. Works great now! It's worth a check. Settings, more networks, mobile networks, network mode..
    beh and nikkeya like this.
    11-17-2014 10:53 PM
  23. byrds8's Avatar
    I tried that it did not do anything for it. What is weird is when it reboots it will hit 5bars and sit about -84dbm until its done booting up then drops to like -98dbm. Its almost acting like the radio is not as sensitive as it should be so its ignoring the rest of the signal in. I dont think I have ever seen this phone hit 5 bars even outside.
    11-23-2014 03:45 PM
  24. scallawag's Avatar
    I live in a very fringe area most phones and carriers drop calls and Verizon is the only carrier to have. I don't look at the signal strength readings as they don't matter to me. On the N4 the calls don't drop and are very clear web pages load nicely I do see in the status bar the phone changing from 4G to 3G and back but I don't care about that as long as the phone preforms good.
    In my constant search for the best call, data, GPS, reception I have tried many phones the ones I still own are LG G3, Droid Turbo, Droid Maxx, Samsung S5 and Note 4.
    The Note 4 is hands down the very best. It is so much better it is no contest. On the G3 and Maxx I have to sometimes go out on the porch to keep calls form dropping and they are the second best. The Turbo is the absolute worst.
    It's so nice to just sit at my desk and talk that I think this Note 4 DE will be with me for A very long time.
    11-24-2014 07:14 AM
  25. BFGOD's Avatar
    Thanks. That was my problem
    11-24-2014 01:31 PM
29 12
  1. Vibration strength seems weak
    By dcastillo in forum Moto 360
    Last Post: 04-26-2016, 09:40 PM
  2. You can return a signal Booster to a store?
    By Closingracer in forum General Carrier Discussion
    Last Post: 11-18-2014, 06:09 PM
  3. Why is my Galaxy S4 signal dropping?
    By Babilon39 in forum Samsung Galaxy S4
    Last Post: 11-14-2014, 10:58 AM
  4. Battery drain and dropped WiFi signal
    By lizette1222 in forum Samsung Galaxy Note 4
    Last Post: 11-13-2014, 01:45 PM
  5. loosing signal while tethered.
    By kazue00 in forum Ask a Question
    Last Post: 11-11-2014, 11:49 PM
