1. stonedgolfer's Avatar
    Ive had the note 4 for about 3 weeks now..I love it...still all original, stock. I went to charge it tonight and I got like an alarm tone when I plugged in the charger and a message appears saying something along the lines of charger not compatible and to verify that it is a samsung charger...again, I cant remember the exact message as now my phone has died so I cant see it..but it was something to that effect...it wont charge the phone at all now..when its dead and I plug it in, it brings up the big battery display with the lightning bolt as to show it is charging but within about 5 seconds changes to a yellow triangle with a crossed out battery as to say not charging. So now im not able to even turn my phone on because it has 0 battery. This is the default charger and cord....any experience with this issue would help greatly..thanks
    11-16-2014 12:15 AM
  2. swade8's Avatar
    What happens if you use the Samsung USB cable and plug it into your computer's usb port? I know it won't charge fast, but see if the trickle charging process works. And if it does, you may have a faulty A/C adaptive charger now.
    Sent from The One and Only, Amazing---> Note 4
    11-16-2014 12:20 AM
  3. swade8's Avatar
    And don't try to turn the phone on, till it at least reaches 5%, 10% is better.
    Sent from The One and Only, Amazing---> Note 4<---
    11-16-2014 12:23 AM
  4. stonedgolfer's Avatar
    Same exact thing, yellow triangle saying its not charging...I dont even get to the display where it says 0%. Also tried using my old note 3 charger and same thing, which is telling me its most likely the phone...
    11-16-2014 12:25 AM
  5. stonedgolfer's Avatar
    Well since we isolated it to the phone by trying different chargers but getting the same issue, I pulled the battery and sure enough its now charging on the original charger...
    11-16-2014 12:35 AM
  6. swade8's Avatar
    Here's a long shot, remove the battery, wait 15 seconds, then place it back in
    11-16-2014 12:41 AM
  7. swade8's Avatar
    I've heard that just doing that is like magic, and I've witnessed it too for other odd things, it solved a friend of mines audio issues, believe it or not, yesterday.
    11-16-2014 12:42 AM
  8. swade8's Avatar
    Sorry I didn't see this response before I made a post..
    11-16-2014 12:43 AM
  9. swade8's Avatar
    Glad it charging
    11-16-2014 12:45 AM
  1. S4 antenna problems
    By Cannadude in forum Samsung Galaxy S4
    Last Post: 11-20-2014, 07:47 PM
  2. chrome browser problem
    By wildfan1976 in forum Sony Xperia Z3v
    Last Post: 11-19-2014, 01:53 PM
  3. Big problem on my Nexus 7 and Android 5.0
    By Converted007 in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-17-2014, 10:49 AM
  4. Big problem with Android 5.0 on my Nexus 7 (2013)
    By Converted007 in forum Android 5.0 Lollipop
    Last Post: 11-16-2014, 12:14 PM
  5. Charging issues?
    By kjmi64 in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 11-16-2014, 11:02 AM
