1. Dankees's Avatar
    So, my battery was previously doing an amazing job. Over the past couple of days, I noticed that it hasn't been doing as well as before.
    It still does a great job, but it's not as good, and I really cannot figure out why.
    Any ideas?
    (I even keep the phone on Power Saving Mode at all times.)
    11-16-2014 09:04 PM
  2. rvhs03's Avatar
    Did it start around the time you downloaded a specific app? Apps are usually the main cause of sudden dramatic battery drain. You can download battery managers to give you more detail on what is eating your battery than what the stock UI shows.
    Dankees likes this.
    11-16-2014 09:53 PM
  3. LaTuFu's Avatar
    I would also suspect recently downloaded apps.
    Another possibility is roaming. Were you traveling and roaming during the period when you noticed that the battery wasn't doing well?
    Dankees likes this.
    11-16-2014 09:58 PM
  4. Dankees's Avatar
    Yeah, it could be a recent application.
    I mean, I am sitting at work, not really using the phone much at all, and I am not really losing any power (or not much), just like before.
    I just downloaded the Battery Guru application to maybe see what might be running on my phone (if anything).
    What other applications can we all use?
    I don't think that BetterBatteryStats works.
    11-17-2014 10:37 AM
  5. hdhuntr's Avatar
    GSAM seems to have LOTS of info in it...
    Dankees likes this.
    11-17-2014 12:56 PM
  6. Dankees's Avatar
    What's that?
    11-17-2014 02:43 PM
  7. Dankees's Avatar
    Something else to consider; when is the last time you rebooted or powered off/on? Because I've seen behind the scenes updates to Google Play Services or Play Store cause unexpected increase in battery drain until a reboot sets things straight again.
    Each night.
    11-17-2014 02:43 PM
  8. dpham00's Avatar
    What's that?
    App from the play store
    Sent from my Verizon Samsung Galaxy Note 4
    Dankees likes this.
    11-17-2014 03:40 PM
  1. Ringtone keeps switching to "unknown ringtone"....why?
    By andrea java in forum Motorola Droid Turbo
    Last Post: 06-24-2016, 10:38 PM
  2. How much does Web browser hammer the battery?
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 11-17-2014, 08:39 AM
  3. How do I clean my wifi antenna on my Galaxy S4?
    By Anthony Casotti in forum Ask a Question
    Last Post: 11-17-2014, 01:23 AM
  4. Why won't my Nexus 5 connect to the internet?
    By Knorske in forum Google Nexus 5
    Last Post: 11-16-2014, 09:49 PM
  5. Why does my keyboard type the incorrect number/letter?
    By arthurprigodich in forum Ask a Question
    Last Post: 11-16-2014, 09:11 PM
