1. BigCrimsonTX's Avatar
    If so what app should I use?
    Thanks in advance!
    11-17-2014 12:18 AM
  2. Rukbat's Avatar
    The Note 4 shows you the battery state without an app. If you want to save battery, turn off all radios you aren't using, keep the screen as dim as you're comfortable with, keep the screen shutoff time low (15-30 seconds). And you can use Greenify to save more power.
    11-17-2014 12:40 AM
  3. pantlesspenguin's Avatar
    The phone comes with two different power saving modes. I'd use these before using a third party app. I used Juice Defender for years, but now it's useless on devices with their own native power saving settings.
    11-17-2014 10:04 AM
  4. hdhuntr's Avatar
    Look at GSAM
    Thanks in advance!
    11-17-2014 12:56 PM
  1. How do you feel about not receiving the ota update
    By xban1 in forum Legacy Android & Other OS's
    Last Post: 01-31-2015, 10:27 PM
  2. What do you set your brightness to?
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 11-17-2014, 07:22 PM
  3. Galaxy Note 4 storage.
    By wwightman16 in forum Ask a Question
    Last Post: 11-17-2014, 07:30 AM
  4. Which one is better Samsung Galaxy Note 4 vs Samsung Galaxy A7?
    By Chi Hyun Ahn in forum Samsung Galaxy Note 4
    Last Post: 11-17-2014, 12:10 AM
