Samsung Galaxy Note 4 exchange sync issue
reaperthekeeper
Ever since the 4.4.4 upgrade my exchange won't stay connected to my corporate exchange server (2007). I did a factory reset and it worked for two days then stops connecting again, managed to get it to connect for a day but stopped again. WiFi is off, data sync/email sync is on, power save off, full bars and 4G LTE service (TMobile). Battery at 75%, never got below 15% since the factory reset. Frustrated because this doubles as my corporate phone. Any ideas I might be missing?
plumcrazy
454
Re: exchange sync issue
it can definitely be on the server side but im not a fan of the stock exchange at all. i use touchdown for my exchange email, much better IMO
mty msi
769
3
I've had my MS Exchange account running through the stock app since day one with zero problems. I know MS says if you set up an Exchange acct. as an IMAP or POP account rather than an actual Exchange acct. it won't sync the calendar & tasks. Are you setting it up as an actual Exchange acct.? Don't know if that may be the cause of your problem but I thought it worth mentioning.
pstellato73
358
13
I have been connected since I had the note 4 as well, but using touchdown. I also installed mobimail and it has been connected since I set it up as well.
plumcrazy
454
i tried mobimail a while back (2-3 phones ago) and it jammed my phone up pretty good. might need to try it again and see how it is
worwig
990
50
I use Exchange with our company Exchange 2007 server. I also use it to sync to my Outlook.com email.
Works well, but I found that if I use push, like I used to on my Galaxy S4, it sucks the battery AND uses a huge amount of data. So I use a 15 minute schedule. Good enough.
LaTuFu
817
I have my O365 account set up with push and have not had issues with data or battery. But I don't have a server setup in addition, maybe that is the difference.
