1. MightyMike's Avatar
    Can anyone tell me how to turn the temperature off on lock screen? It always reads 36°. If it was correct I wouldn't mind leaving it on...but in 2 days we went from 70° to about 22° and it always says 36°. Drives me batty. I did put weather bug elite on my phone. I would like to put that widget on lock screen but don't know how to do that either....Lol. Thanks for any help! Don't know if y'all need this info or Not...AT&T, Note 4, South Carolina, USA.
    11-19-2014 09:16 AM
  2. lsmachado's Avatar
    Have you tried adjusting the settings? Once you log in to your device, tap the temperature, thentap the 3 vertical dots on the upper right corner>Settings>Auto Refresh. Make sure your option is NOT set to "None". Mine is set to update hourly. Maybe that will help.
    Additionally, there is an option to check "Auto Refresh On Opening".
    Posted via the Android Central App on my awesome Note 4
    MightyMike and skatergirl like this.
    11-19-2014 09:26 AM
  3. MightyMike's Avatar
    Got it...thank you very much! You saved my sanity! Lol
    11-19-2014 09:40 AM
  4. MightyMike's Avatar
    I didn't find a refresh button or options for refresh rate....but I did find an on/off toggle. Turned it off then back on and works now. Thanks again!
    11-19-2014 09:45 AM
  5. beh's Avatar
    If you are using the stock AccuWeather widget that is pre-loaded on your phone the GPS has to on for the widget to update as it looks for the nearest weather station to poll from, if I read the widget weather info correctly.
    11-19-2014 11:07 AM
  1. How do I remove apps from lock screen?
    By neural tube in forum General Help and How To
    Last Post: 11-21-2014, 03:21 AM
  2. Is there an Android Updater for the Galaxy S4?
    By David Luke in forum Android 5.0 Lollipop
    Last Post: 11-20-2014, 12:40 PM
  3. Cant seem to root or unlock my AT&T Galaxy s4 i337 version.
    By cjcurtis70 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 11-20-2014, 05:42 AM
  4. Why am I unable to upgrade to Android 5.0 on my Nexus 5?
    By Jan Tugsbayar in forum Ask a Question
    Last Post: 11-20-2014, 05:19 AM
