1. RecoveringAppleUser's Avatar
    Is there a faster way to switch between apps on the note 4? On the note 3 you just held down the home button and you would get a selection. Now you have to press the button to the left and it lags quite a bit. I'm new to android and i'm wondering if there is a way to change the "card stack" that's represented by apps for multitasking.
    thanks,
    11-19-2014 10:04 PM
  2. twolastnames's Avatar
    Rumor has it switching to ART fixes it. That is in the developer menu, but I would check into it first, because it can affect apps in a bad way. Also, you need to enable the developer menu, tap on the build number 7 times in the settings menu - about phone. Beware though, there are demons in that menu, and you can make life hard for yourself messing around with stuff you don't know about. There is a reason it's hidden in other words.
    11-19-2014 10:13 PM
  3. RecoveringAppleUser's Avatar
    thanks for the quick tip. I'm a techie so I can deal with it. I read earlier that there is a way to disable animations, so I'm going to try that. It's good to know I didn't have to anything fancy to get into developer mode.
    thanks again!
    11-19-2014 10:21 PM
  4. twolastnames's Avatar
    Disabling animations all together is ill advised as well. It actually makes the phone seem laggy. I turn mine to .5 and heavily prefer that. It won't help with the Laggy recents though.
    11-19-2014 10:51 PM
  5. muzzy996's Avatar
    I use SwitchR. I set it to Flow and use a right side trigger point. Works much better than the two step recent button method.
    11-19-2014 10:55 PM
  6. rosenbluu's Avatar
    I actually prefer mine higher then what the stock is, I have mine at 2. Makes the phone feel like there's no lag, imitates how the iPhone animations are
    geoffr86 likes this.
    11-19-2014 11:06 PM
  7. twolastnames's Avatar
    I just switched to ART to try. Can confirm app switching is normal. Just so you know, it took about 30 minutes, and the phone almost burst into flames it was so hot.
    11-19-2014 11:19 PM
  8. brancross's Avatar
    I strongly agree with you
    Not every single app was designed specially for 4.4 ART MODE
    It died several times when I started some APP, then I turned it back to normal Mode......
    11-19-2014 11:22 PM
  9. twolastnames's Avatar
    What 2 step recent button method? There is a dedicated app swtiching button on the Note 4.
    11-19-2014 11:22 PM
  10. youngnahj's Avatar
    Thanks for this tip, I admittedly would always set it to .5 as well. After reading your post I set it to 2 and the animations see much smoother now.
    11-20-2014 01:41 AM
  11. Almeuit's Avatar
    Mine lags as well. I haven't tried art yet though.
    11-20-2014 01:45 AM
  12. JRLasVegas's Avatar
    thanks,
    Why not use the stock multitasking app? You quickly switch between apps. Look at the bottom right picture of my screen. My last app is there and all I have to do is touch it. Doesn't get any faster than that.
    Is there a faster way to switch between apps on the note 4?   Multitasking-uploadfromtaptalk1416465937915.jpg
    Sent from my SM-N910T using Tapatalk
    11-20-2014 01:46 AM
  13. muzzy996's Avatar
    Two step as in you have to tap that recents button once, wait for the scrollable list to pop up, scroll and select the application you want.
    With switchr a simple swipe inwards from the upper right edge of my screen with my right thumb starts me scrolling through icons of recent applications and as soon as the one I want is highlighted I let go of my thumb and the application opens. One stroke, done.
    The application is free and doesn't need root.
    Sent from my SM-P900 using Tapatalk
    11-20-2014 02:26 AM
  14. LaTuFu's Avatar
    Not always. I run 0 animations just fine.
    Katrina White1 likes this.
    11-20-2014 05:32 AM
  15. dpham00's Avatar
    I use pie control. It can access recent apps without lag.
    Sent from my Verizon Samsung Galaxy Note 4
    11-20-2014 10:24 AM
  16. pdub73's Avatar
    I have mine set to zero and i experience no lag
    11-20-2014 10:32 AM
  1. Facebook messenger app the camera
    By JohnnyG44 in forum Samsung Galaxy Tab 3
    Last Post: 12-04-2014, 05:39 PM
  2. Anyone else keeping Note Edge as phone and Note 4 for VR?
    By 67srbell in forum Samsung Galaxy Note Edge
    Last Post: 11-23-2014, 06:27 PM
  3. Lollipop Tablet UI is a huge step BACKWARDS
    By crxssi in forum Google Nexus 10 Tablet
    Last Post: 11-22-2014, 12:58 PM
  4. How do I take Lollipop of my Google Nexus Tablet 2012?
    By Terri Whitmarsh in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-20-2014, 01:30 PM
