1. MAILROOMMANUK's Avatar
    Hi all this is my second note 4 since launch
    My issue is a problem were by when i get a call or make a call while im listening / streaming music from google music or firetube .
    Even after uninstalling the 2 apps the problem continues .
    You can see the 4G drop off to 3G or hsdpa
    And then goes to O/ slash through a circle no network at all for about 10 - 20 seconds and then starts back up to 4G again .
    Often i have to turn the phone off and on again to clear the issue .
    Ive had new sim cards from three mobile and told any amount of its this or that
    Bulls--t.
    Factory restore after restore and and it lasts for 2 or 3 days then bang again .
    Has anyone any ideas or had the same issue or will to try streaming music to see for your self .
    It cant be a one off as this is the secound time .
    Im thinking three are going to tell me to go away before much longer .
    11-20-2014 08:22 AM
  2. dpham00's Avatar
    Which variant do you have? I have used Google music and made a call and it remained on 4GLTE.
    Sent from my Verizon Samsung Galaxy Note 4
    11-20-2014 10:18 AM
  3. MAILROOMMANUK's Avatar
    Im using a european note 4 on three uk network .
    Sm-n910f google play V5.7.1717Q
    If that helps
    11-20-2014 03:59 PM
  1. Best Back-up solution for my Note 4
    By srechatt in forum Samsung Galaxy Note 4
    Last Post: 08-12-2015, 01:04 AM
  2. What is the best comprehensive backup solution for Note 4?
    By srechatt in forum General Help and How To
    Last Post: 11-24-2014, 12:38 AM
  3. Samsung note 4 wifi blocking Google and Hotmail
    By Jay Arthur in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 06:31 AM
  4. Call receiving error after lolipo update
    By Vinit Choudhary in forum Legacy Android & Other OS's
    Last Post: 11-21-2014, 04:55 AM
  5. "Backup Lite" high battery and GPS usage?
    By yo0123yoyo in forum Samsung Galaxy Note 4
    Last Post: 11-20-2014, 04:01 PM
