1. ACGuest's Avatar
    Hello, after some research I am confused as to what the unlocked international version of the Galaxy Note 4 is. People are saying that it is SM-N910C, but I have also read that it is SM-N910F/H/U.
    11-21-2014 02:34 PM
  2. jpr's Avatar
    There are something like a dozen of them. You'll have to be more specific. The most widely used ones are 910F, 910C, and 910U but there are several other unlocked international models.
    11-21-2014 05:25 PM
  3. ACGuest's Avatar
    Apologies. Which one is the most versatile in terms of traveling worldwide. Does any of the C/F/U work on LTE in the US?
    11-21-2014 07:33 PM
  4. jpr's Avatar
    All three of those will work on some carriers LTE bands in the US. If you want to use a particular carrier then you should look up the specific bands. The F is a Snapdragon processor and other two are Exynos. The F and C have the most bands overall.
    11-21-2014 07:48 PM
  5. ACGuest's Avatar
    I see, though I am still confused about one thing. Since the C model is from the Taiwan, Europe, etc. Does it contain the bands of all of those regions or only the region it came from?
    11-23-2014 07:14 AM
  1. slide to unlock grayed out
    By Kingfroman in forum Android 5.0 Lollipop
    Last Post: 06-16-2015, 11:25 AM
  2. Replies: 3
    Last Post: 11-24-2014, 10:26 AM
  3. Replies: 2
    Last Post: 11-22-2014, 07:49 AM
  4. How can I use my unlocked Verizon S4 Mobile Hotspot?
    By nellysanchez20 in forum Samsung Galaxy S4
    Last Post: 11-21-2014, 02:01 PM
  5. Note 4-Can't pull down Notification Bar
    By yyahalom in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 01:44 PM
