1. danielhouse2010's Avatar
    I just purchased my Note 4 a few days back and for some reason they will not connect to each other. I can get them paired but it always says "disconnected"..
    Is anyone else getting these issues? I have did multiple un-pairing and re-pairing with no luck
    Thank you!
    11-23-2014 10:14 PM
  2. Rukbat's Avatar
    Both are servers, you need an app if you want to transfer files between them.
    11-23-2014 10:29 PM
  3. estebancam's Avatar
    Did you make sure to download the android wear app first?
    You need to pair the device via Bluetooth and when it pairs, go to the android wear app and connect it there. It will work.
    11-24-2014 12:46 AM
  4. pathfinder3's Avatar
    I had to reset my Moto 360 in order for it to sync with my phone.
    Sent from my SM-N910V using Tapatalk
    danielhouse2010 likes this.
    11-24-2014 04:12 AM
  5. danielhouse2010's Avatar
    This worked! Thank you very much!
    11-26-2014 08:41 PM
  1. Replies: 28
    Last Post: 02-12-2015, 12:24 AM
  2. Why is my LG G3's battery draining rapidly?
    By tmccain in forum Batteries
    Last Post: 12-01-2014, 07:08 PM
  3. Do you have HDR on or off?
    By Budi Sudaryo in forum Samsung Galaxy Note 4
    Last Post: 11-24-2014, 03:36 PM
  4. Replies: 1
    Last Post: 11-23-2014, 10:06 PM
  5. Replies: 1
    Last Post: 11-23-2014, 09:41 PM
