1. saicoboy's Avatar
    Hi well i was installing supersu in my rooted note 4 and it asked me to install by twerp which i agreed, it automatically took me to twerp and installed an update and reboooted after that, it displayed samsung logo, then tmobile's logo and that's as far as it goes and reboots again and again... it never goes into the menu.... i went into recovery mode and tried everything i though of like clearing cache, factory reset, data wipe, etc... and the thing just doesn't work. any ideas???
    11-24-2014 01:46 AM
  2. saicoboy's Avatar
    11-24-2014 02:29 AM
  3. Tkbredx's Avatar
    Did you try fixing permissions? When it says install on supersu you're supposed to hit normal. Not twrp. Or at least from
    What I understand.
    You may have to start over and wipe, odin stock, root and flash twrp again.
    I'm not really sure. Android Central isn't that great of a place to ask this. While I'm sure there's somebody with the right answer here, you'll probably get it much quicker on XDA.
    I've rooted multiple times but with every flash I still feel like a noob. Wish I could help you man.
    11-24-2014 03:04 AM
  4. rcobourn's Avatar
    I've gotten out of this by just using Odin to flash the current firmware and stock recovery, no need to wipe.
    11-25-2014 08:17 PM
  5. harryhoudini66's Avatar
    You will need to Odin flash as suggested by others. It is actually very simple. Next time you update Superuser, use normal mode unless you actually have a custom recovery like TWRP.
    11-25-2014 08:24 PM
  1. Note 4 wont connect to Moto 360 what is going on?
    By danielhouse2010 in forum Samsung Galaxy Note 4
    Last Post: 11-26-2014, 08:41 PM
  2. Note 3 ruined by new update?
    By f1wannab in forum AT&T Samsung Galaxy Note 3
    Last Post: 11-25-2014, 07:05 PM
  3. Replies: 18
    Last Post: 11-25-2014, 05:47 PM
  4. Query on choosing a tablet for one note
    By Scuzzball in forum General Help and How To
    Last Post: 11-25-2014, 02:34 PM
  5. Replies: 13
    Last Post: 11-25-2014, 11:27 AM
