Can't see the percentage in that picture, but the usage per app seems about normal.
Probably an app, something is keeping the phone awake even while the screen is off. Just checked my battery stats and my phone is pretty much only awake while my screen is onhttp://tapatalk.imageshack.com/v2/14/11/25/a614a0251dae21f47d62249b4dd9f8e9.jpg
Sent from my SM-N910V using Tapatalk
Do you charge your phone every night or only when it gets low?
Also, when you do charge, do you set it to Fast Charge or normal?
It looks like it is a combination of some app of yours is waking up periodically and running in the background, and you were in an area with weak signal for an extended period of time. That will make the radio spin around looking for a better signal, which will run down battery. Is that normal use for you, or were you traveling to an area you don't normally go to on a daily basis?
Hmm. About the same as me. But your graphic is showing much lower than that during some parts of your day.
Retail floor.What kind of work environment are you in most of the time? Around machinery generating a lot of EMF? An office environment? Retail floor?
That's so much work lol guess I'll do itI've had the same problem with mine. I had the same problem with the Note 3 as well. With the Note 3 I noticed a drastic loss of battery time after a T Mobile update. I ended up doing a factory reset and that cured it. After a few weeks with the Note 4 the same battery drain started happening.This time there was no update that I could tell. Did some tweaks to try to help but ended up doing a factory reset and again, that totally fixed it.,
http://tapatalk.imageshack.com/v2/14/11/25/8246ba3b24076136c3ebb285f8e12691.jpg
And with like 48 minutes if screen time
Here's mine with 3 hours screen on time
I have just over 3 hours screen on time vs his 1 hours and 18 minsHis shows 12 hours and 55% yours is 10 hours and 55% also, so his is acutely better then yours.
