1. only foryou's Avatar
    I am using clean master and cm security... Are they really work? I mean removing the junk and providing security? Will they drain battery?
    Thanks..
    11-28-2014 05:31 PM
  2. Rukbat's Avatar
    If you're using it as a malware cleaner, yes, but there are better ones. If you're using it to "clean" RAM, NO! Androd isn't Windows, it doesn't want a lot of free RAM. Free RAM is wasted RAM. It wants RAM as full as possible. So if Clean Master "cleans" an app out of RAM, and Android wants it in RAM, it'll reload it. Then Clean Master will "clean" it out again. Then Android will load it again. Etc., etc., etc.
    That eats your battery for lunch.
    only foryou likes this.
    11-28-2014 05:37 PM
  3. only foryou's Avatar
    So you suggest that not to clean the ram? Some times I get a warming saying that my processor is hot and need to cool it... Then it kills all the apps running and cools it down!!
    11-28-2014 05:47 PM
  4. ColbyJvonBrown's Avatar
    Same thing on my Moto G 2013 my phone will get hot when playing a game and surfing the web or watching YouTube and it says my CPU is at 154°!!!! So I don't know if it's just cm or cm security and it always says clean my ram so I do, but I don't know if that's true or not but any info on this will be great. And my battery dies really fast.
    11-28-2014 06:12 PM
  5. LaTuFu's Avatar
    Android OS does not need RAM management or app killers.
    11-28-2014 09:06 PM
  6. only foryou's Avatar
    Dear LaTuFu,
    Here we are discussing about weather they really do the job or its just a trick? Its wastage of space and battery? how relaiable are such apps?
    Thanks for your comment!!
    11-29-2014 12:59 AM
  7. pdub73's Avatar
    I hear this a lot but i find when my ram usage is high my fb app lags...and sometimes won't open pictures or update the newsfeed it just spins...i wait and wait but nothing finally i go clear some apps running in the background and it starts to work, happened on my note 3 as well can anyone explain this?
    11-29-2014 06:35 AM
  8. boufa's Avatar
    The FB app may be the worst app ever written. And FB doesn't really care, they have their billion users (about 100,000 of which are active). Try using FAST for FB instead and see if it helps.
    11-29-2014 06:58 AM
  9. Javier P's Avatar
    I think that some apps need a regular cache clearing more than a RAM management. The first in my mind are Chrome, FB ... And that can be done manually in the settings with no need of a cleaner app. By the way, your phone will be happier if you forget the FB app and access from the browser
    I used Ccleaner for a little while and uninstalled it. I consider those apps a waste of battery and resources.
    A regular cache clearing and rebooting the phone at least once a week improves performance.
    bassplayrguy likes this.
    11-29-2014 07:09 AM
  10. Duncan1982's Avatar
    I agree I used these apps for a while and pointless as I then done some reading and learned how Android utilises ram.
    Clearing cache through a reboot or recovery is enough for me and overall better for my phone.
    Javier P likes this.
    11-29-2014 07:17 AM
  1. Replies: 6
    Last Post: 03-09-2015, 09:31 PM
  2. Battery app
    By only foryou in forum Samsung Galaxy Note 4
    Last Post: 11-30-2014, 06:43 AM
  3. Replies: 6
    Last Post: 11-28-2014, 08:18 PM
  4. I can't swipe away the Battery Saver notification
    By kal1209 in forum Google Nexus 4
    Last Post: 11-28-2014, 05:21 PM
  5. Why does Tap and Go setup assistant set the wrong owner account?
    By essercizi in forum Android 5.0 Lollipop
    Last Post: 11-28-2014, 04:19 PM
