1. bassplayrguy's Avatar
    I think my proximity sensor may be bad. My smart stay will not keep the screen on while I am looking at it, however it turns the screen off when I have the phone to my ear and turns it back on when I pull the phone away from my ear. Any ideas???
    12-01-2014 09:24 AM
  2. worwig's Avatar
    Isn't that exactly what the proximity sensor is supposed to do?
    It turns off the display when you have it at your ear, since it can't be see anyway, and would just be draining the battery. And it locks the touch screen so your ear doesn't touch the buttons.
    12-01-2014 09:58 AM
  3. dpham00's Avatar
    Do you have a problem with smart stay in a bright environment?
    Sent from my Verizon Samsung Galaxy Note 4
    12-01-2014 09:58 AM
  4. bassplayrguy's Avatar
    But smart stay is not working. Is that a different sensor?
    12-01-2014 02:41 PM
  5. bassplayrguy's Avatar
    Ok so I just tried it again. It apparently only works in very well lit areas.
    12-01-2014 02:44 PM
  6. dpham00's Avatar
    Yeah smart stay doesn't work well in lower lit areas
    12-01-2014 05:06 PM
  7. bassplayrguy's Avatar
    Seems like the s5 worked in dim light
    12-01-2014 07:35 PM
  1. Anyone have any idea how to help?
    By lostboycot in forum Samsung Galaxy S4 Mini
    Last Post: 12-01-2014, 12:52 PM
  2. Are there any private camera apps?
    By jhguth in forum Android Apps
    Last Post: 12-01-2014, 12:48 PM
  3. Replies: 1
    Last Post: 12-01-2014, 01:25 AM
  4. Replies: 2
    Last Post: 11-30-2014, 11:16 PM
  5. Replies: 2
    Last Post: 11-30-2014, 02:33 PM
