1. dakid2k6's Avatar
    I have attached some shots. Anybody know how to stop the notifications from automatically extending themselves. I don't know what I did and can't fix it. I know 2 fingers and slide up makes it small as in photo #2 but that doesn't fix it permanent. And it wasn't like that before. Would like it back to original state where the notifications are like photo #2 not like photo #1
    Attached Thumbnails Help with notification tray-screenshot_2014-12-01-10-02-31.jpg
    12-01-2014 10:07 AM
  2. srkmagnus's Avatar
    I don't see the second image. However, based on the photo I can see, it looks like the notification is coming form a Twitter client - not sure which one though. Is this happening with all notifications? Or just certain ones, or notifications from Twitter?
    If it's Twitter, then I'd suggest going through the client to disable any options for advanced settings in the notifications tray.
    12-01-2014 12:47 PM
  3. Almeuit's Avatar
    I can only see the one screenshot but that looks normal. If there is room it expands more .. But when you have a lot of notifications they will be smaller to take up less space.
    12-01-2014 12:51 PM
  4. dakid2k6's Avatar
    Happens with all notifications.
    12-01-2014 12:55 PM
  5. dakid2k6's Avatar
    Winder why the other wasn't posted. I will upload another and show. But the notifications never did that before unless I made them by putting my finger in it and pulling down. Now in reverse they still don't go back to normal
    12-01-2014 12:57 PM
  6. dakid2k6's Avatar
    Here's what they used to do. Not just twitter but all notifications, email text missed calls etc.
    Attached Thumbnails Help with notification tray-screenshot_2014-12-01-13-00-26.jpg
    12-01-2014 01:01 PM
  7. PaulaO's Avatar
    It seems to be inconsistent. Sometimes mine are all YOU HAVE A NOTICE and sometimes they are manageable. I hope there is a permanent setting. But I didn't know about the 2 finger thing so that must be what I am doing to keep changing it around I reckon.
    12-01-2014 08:26 PM
  8. dakid2k6's Avatar
    It seems that's the only way I can manage them is the 2 finger swipe. It's annoying because I have to scroll down sometimes all thru to get to the important ones first
    12-02-2014 10:55 AM
  9. raicas's Avatar
    it's an android feature, I think you cannot stop that
    12-02-2014 02:17 PM
  10. dakid2k6's Avatar
    I don't think you cannot stop it. I'm sure there is a way as the phone doesn't do this when brand new out the box.
    12-02-2014 03:14 PM
  11. dakid2k6's Avatar
    Update here and uninstall a few apps and reinstall doesn't help this issue. Anybody with any clues or insight to how to fix this.
    12-03-2014 01:10 PM
  1. Why am I not able to crop photos with the app QuickPic?
    By garryg in forum Samsung Galaxy Tab S 8.4
    Last Post: 12-04-2014, 09:15 PM
  2. Replies: 32
    Last Post: 12-02-2014, 01:54 PM
  3. How can I transfer my game data off of my phone without using Helium?
    By darksider13666 in forum Samsung Galaxy S3
    Last Post: 12-02-2014, 03:43 AM
  4. Problem with my m8
    By ForeverSol in forum HTC One M8
    Last Post: 12-02-2014, 03:18 AM
  5. Anyone have any idea how to help?
    By lostboycot in forum Samsung Galaxy S4 Mini
    Last Post: 12-01-2014, 12:52 PM
