1. countduckula55's Avatar
    Hi, I just wanted to check if I need to avoid certain model numbers for use in the UK. I have been reading for hours but I'm confusing myself even more! I believe the UK version is n910f but I've found a good deal on a n910u. Would this work OK in the UK or am I better off paying extra for the f? Thanks
    12-01-2014 06:12 PM
  2. Duncan1982's Avatar
    There are two versions of the Note 4
    1)Snapdragon 805 which here in the UK is under SM-910f.
    2)Exynos Octa Core which is under SM-910c or SM-910u.
    And to further answer your question yes the Exynos is just as good and in some aspects better than the Snapdragon and vice versa.
    12-01-2014 06:19 PM
  3. countduckula55's Avatar
    Thanks for the reply. So the octa core version will work OK in the UK. Cheerx
    12-01-2014 07:25 PM
  4. Duncan1982's Avatar
    No problem and yes piece of mind it does :-)
    12-01-2014 07:33 PM
  5. countduckula55's Avatar
    Thanks for your help :-)
    12-02-2014 01:23 PM
  1. Replies: 6
    Last Post: 05-13-2016, 01:38 PM
  2. Size Difference
    By Jean Sagarese in forum Samsung Galaxy Note Edge
    Last Post: 12-02-2014, 09:03 PM
  3. changing shortcut apps on note 4 flip cover window. .
    By htc evo 4g in forum Samsung Galaxy Note 4
    Last Post: 12-02-2014, 09:25 AM
  4. Mobile Network settings missing on Tegra Note P1640?
    By macselite in forum Ask a Question
    Last Post: 12-02-2014, 01:34 AM
  5. Note 2 gets hot
    By alexx1227 in forum Samsung Galaxy Note 2
    Last Post: 12-01-2014, 04:09 PM
