1. janje's Avatar
    Hi can anyone tell me what does the arrow means on the screenshot and please tell me how to get rid of it.
    Thanks..
    12-01-2014 08:36 PM
  2. Nakrohtap's Avatar
    I just checked the icon glossary and it's not in there. It must be a downloaded app that you installed. Is it there all the time? Can you look at your "running" apps to try and narrow it down?
    12-01-2014 10:57 PM
  3. iGalione's Avatar
    carrier, variant? any of that would also be helpful as well... I want to say wifi direct, but it is different, acutally has that with a fan blade on top
    12-01-2014 11:45 PM
  4. MightyMike's Avatar
    The only time I have ever seen those 2 arrows was when I was receiving an ATT update for the phone.
    Posted via the Next Big Thing, My Galaxy N4
    12-02-2014 12:59 PM
  5. Almeuit's Avatar
    What carrier are you on?
    12-02-2014 01:08 PM
  6. misterizzat's Avatar
    Hi.. im currently facing the same issue for my note edge.. asked several phone shops but none could solve it.. some said it relates to the call settings- voice over LTE allowances... im still waiting for the solution/updates on how to remove the arrows icon...
    01-16-2015 12:07 PM
  7. lv2bsilly's Avatar
    Do you have "download booster" enabled?
    01-16-2015 12:28 PM
  8. Noni Arif's Avatar
    it is called the VoLTE. if you. If you go to Mobile Networks > Network Mode and change it to some other setting. that arrow will disappear.
    02-09-2015 11:39 PM
  9. Kristin PandaCandy's Avatar
    My note edge also got the same thing... I think is linked to LTE.. I tried changing the mobile network from LTE to GSM, the arrows disappear... But appear again when i which back to LTE..
    02-26-2015 02:38 PM
  10. faiz0323's Avatar
    Thanks..
    go to settings> mobile networks> access point names. you should only be seeing 1 data access point and 1 mms access point. if u are seeing more than 1, remove the other that is not in use.
    toenail_flicker likes this.
    10-24-2015 08:14 PM
  1. OPO on AT&T
    By TMavC5 in forum OnePlus One
    Last Post: 01-16-2015, 12:09 PM
  2. What is th ed update t hat I just received?
    By elvyb in forum Samsung Galaxy Note Pro 12.2
    Last Post: 12-03-2014, 04:48 AM
  3. Bluetooth Auto On/Off Ford Sync
    By nezff in forum Samsung Galaxy Note 4
    Last Post: 12-02-2014, 11:50 AM
  4. All files not showing up on phones Download app
    By Drachenfire in forum Motorola Droid Turbo
    Last Post: 12-02-2014, 09:54 AM
  5. Has the Lollipop OTA update stopped for Nexus 7 2013?
    By brendan killey in forum Ask a Question
    Last Post: 12-01-2014, 11:42 PM
