1. Scottahart777's Avatar
    OK Guys Please HELP!!! I just bought a NOTE 4 through ATT and a pair of Samsung Level Over Headphones 299.00..... Sounds great connected through 3.5mm direct cable.... However i bought them for the Bluetooth to Note 4 ..... Music will not turn up loud through Bluetooth on any app or even my MP3's..... I have the sound ALL the way turned up oin Bluetooth and System Audio... This sucks.... please tell me a work around or i am returning this crap..... I wanna listen to my tunes at loud level....
    12-02-2014 02:39 PM
  2. Rukbat's Avatar
    The Bluetooth output level can't be, about all you can do is use a Bluetooth headset that has more output.
    12-02-2014 02:52 PM
  3. SpookDroid's Avatar
    I'm not sure why but mine sounds just fine. Bluetooth speaker for the shower, BT headphones for the pool, BT car stereo and BT home stereo and they all sound loud enough.
    12-02-2014 02:58 PM
  4. Scottahart777's Avatar
    i spent 300 bucks for the best headphones which kick *** with direct connected 3.5mm cable... but when i listen to anything at all off my Note 4 it is only like half the volume? This has got be something i can do to fix this... please help anyone who know droid or Samsung NOTE 4....
    12-02-2014 05:51 PM
  5. kevinpleasants's Avatar
    Make sure your media volume is turned all the way up by pressing the up volume button on your note 4 them touching the setting icon on the volume display. Make sure media is turned up.
    12-02-2014 08:47 PM
  6. ChemMan's Avatar
    You need to return them and get a different set, they are broken.
    12-02-2014 08:54 PM
  7. M3Stang's Avatar
    Keep in mine when using the 3.5mm you are using the phones amplifier. Use the bluetooth and the headset is using its own amplifier which may not be as powerful as the phone's.
    SpookDroid likes this.
    12-02-2014 11:34 PM
  8. SpookDroid's Avatar
    THIS!
    12-03-2014 01:12 PM
  9. Yogi217's Avatar
    I've found that I have to turn the volume up on the Bluetooth device and then the phone. It works on my old Samsung Bluetooth headset.
    12-03-2014 02:23 PM
  1. Screen unlock not working properly on Nexus 5
    By Scott549 in forum Legacy Android & Other OS's
    Last Post: 02-19-2015, 09:58 AM
  2. Droid Maxx battery not even lasting a full day
    By pessen in forum Motorola Droid MAXX
    Last Post: 12-07-2014, 01:21 PM
  3. Wifi, Bluetooth, mobile hot spot no longer turn on
    By craigb_ma in forum Motorola Droid MAXX
    Last Post: 12-04-2014, 06:52 AM
  4. Why am I not able to transfer music from my laptop to phone?
    By salesguy426 in forum Ask a Question
    Last Post: 12-02-2014, 09:41 AM
