1. Carrie Greicar's Avatar
    What is the best app to change the LED notifications on the Note 4? I have tried a couple and they don't seem to work right. Thanks in advance.
    12-02-2014 05:10 PM
  2. SpookDroid's Avatar
    Lightflow seems to be the best overall, but Samsung devices usually take a while to be fully compatible.
    12-02-2014 05:15 PM
  3. Carrie Greicar's Avatar
    ok thanks. I downloaded the free version and it works, but I would like to be able to customize for Facebook notifications and such as well but the full version didn't seem to work as well as the lite one. Maybe I will wait a couple weeks and see if that changes things.
    12-02-2014 05:18 PM
  4. SpookDroid's Avatar
    I know it's not what you want, but you could try NoLED. I looooved it when I had my S2 since it didn't have a notification LED. It doesn't use the LED on your phone to notify you, but rather uses the app's badge and unread notification count on the screen. Since the Note 4 uses AMOLED, whatever is black uses nearly no power, so this is a very battery-efficient app. And the result is, IMHO, very cool. You get a much better view of your notifications, and you can set it to stop displaying them after a while if you didn't see them, stuff like that.
    12-02-2014 05:21 PM
  5. mty msi's Avatar
    I used NoLED on my S1 and the feature I really liked about it is you could use different colors for different notifications (i.e. missed calls, emails, texts). I didn't realize it could still be used. Thanks for the heads up because I think it's far more useful than the stock LED with the same color for every notification. Are you using it on your N4?
    12-02-2014 05:42 PM
  6. SpookDroid's Avatar
    I want to, but I'm not at the moment because...well, I don't know why haha
    I just haven't used it yet.
    12-02-2014 05:59 PM
  7. Carrie Greicar's Avatar
    I might give it a try. I to be able to have a different color for different aps so I know if its something I need to respond to right away. Thanks for the help
    12-02-2014 06:07 PM
  8. mty msi's Avatar
    I just installed NoLED and it's a far superior method of alerts to the Samsung blue LED for everything.
    SpookDroid likes this.
    12-02-2014 07:29 PM
  9. cgg074's Avatar
    How can I turn off the blinking red led notification when battery is low? The S5 has an option for this on the LED indicator settings. Can't find it on the Note 4.
    On the S5 the option says: Low Battery. The red LED blinks when the battery power is low while the screen is off.
    12-03-2014 09:57 AM
  10. SpookDroid's Avatar
    Not an option in mine
    12-03-2014 02:09 PM
  11. Carrie Greicar's Avatar
    I was actually able to get the paid Lightflow program to work. Just had to play with it a little while and tweak some things. Works great. Now my LED's light up different for different things. Thanks for the suggestions.
    12-03-2014 02:32 PM
  12. Almeuit's Avatar
    This. I always use Lightflow if I want to edit the color for LED Notifications.
    12-03-2014 03:16 PM
  13. blitz118's Avatar
    You should also check out light manager in the playstore. I use it and like it a lot.
    12-03-2014 03:25 PM
  14. mty msi's Avatar
    On day 2 of using the NoLED the larger icons I selected have switched to the tiny default boxes and I can't change them back. I think I'll try Lightflow.
    Tried Light Flow and even though I had sound notifications turned off in it my phone was giving an incoming email sound notification every 10 minutes or so without any incoming emails. So I uninstalled it. Will try Light Manager tomorrow.
    12-03-2014 07:12 PM
  1. Replies: 4
    Last Post: 10-20-2017, 12:40 PM
  2. Voicemail Notification doesn’t go away after Lollipop update.
    By MarkSeven in forum Android 5.0 Lollipop
    Last Post: 06-01-2016, 05:23 PM
  3. Turbo LED possibility?
    By mobrules in forum Motorola Droid Turbo
    Last Post: 12-02-2014, 09:35 PM
  4. email notification light
    By waxcrazy in forum LG G3
    Last Post: 12-02-2014, 05:03 PM
  5. How can I remove Quick Settings from the notification area?
    By GeekyGoogleGirl in forum Android 4.4 KitKat
    Last Post: 12-02-2014, 04:49 PM
