1. only foryou's Avatar
    I have seen that my clock widget wouldnt work without location enabled... and the most location users are google system services... if i disable location? will these apps continueosly look for location and drain my battery?
    Thanks guys!!
    12-02-2014 11:16 PM
  2. plumcrazy's Avatar
    i keep mine off, dont notice any battery drain from it
    only foryou likes this.
    12-03-2014 06:22 AM
  3. MightyMike's Avatar
    I keep mine on. Always will. I get great battery life.
    Posted via the Next Big Thing, My Galaxy N4
    12-03-2014 07:59 AM
  4. DreamSTi's Avatar
    No, just the opposite. You will get better life without them on.
    12-03-2014 08:34 AM
  5. worwig's Avatar
    Turning them on will use a LITTLE bit more power.
    It is usually cell tower based, and the phone talks to the cell tower anyway, so it really doesn't use much power.
    I leave mine on all of the time. Yesterday after about 16 hours of moderate use I was down to 66%.
    12-03-2014 10:04 AM
  1. What was the first thing you did when you received your turbo?
    By VZWsucks in forum Motorola Droid Turbo
    Last Post: 12-16-2014, 04:31 PM
  2. Getting awesome battery life, see why
    By Spartacus MD in forum Samsung Galaxy Note 4
    Last Post: 12-04-2014, 01:00 AM
  3. Galaxy Note 4: How to enable/disable location on apps?
    By only foryou in forum Samsung Galaxy Note 4
    Last Post: 12-03-2014, 11:24 AM
  4. why does GPS not work on Waze app
    By PsychoBillyCadillac in forum Ask a Question
    Last Post: 12-02-2014, 09:15 PM
  5. Replies: 0
    Last Post: 12-02-2014, 08:18 PM
