04-06-2017 09:29 AM
233 ... 678910
tools
  1. sstephen17's Avatar
    Quick question. Google Play Services is typically my biggest battery hog. However, I can't disable or force stop it (the options are ghosted out). Is that normal?
    06-04-2015 02:50 PM
  2. Kelly Kearns's Avatar
    I can disable Google Play Services, but that is likely carrier specific.
    Also Google Play can be high and it be an actual app, or location or ad signal, etc.
    06-05-2015 07:45 AM
  3. Lady Grinning Soul's Avatar
    Does the amount of use you get from a fully charged battery GSN4 battery decrease over time? I am assuming so. But my 6 month old N$ has had a dramatic decrease in how long if stays charge literally overnight. My usage has not changed, nor have I changed the apps installed, hidden disabled, etc.
    Used to be when I changed it to 100%, I didn't use it much still be at 100% and hour or two later. With my typical use, it would be down to maybe 40% to 50% after 24 hours, now it can't last 24 hours without fallig below 20. When it dropped from 70 to 40 overnight just sitting there. Six hours before this screenshot it was at about 70%. And it went from that to about 17% in three hours of low use. Nothing "extraneous" running that I have any control over (AFAIK.)
    Galaxy Note 4: Battery Life Concerns Check Here First-luubidu.jpg
    I had something called Google Daemon, or Android Daemon or associated with Google Services or Android System with Daemon in the name that was using most of the battery. It let me Force Stop, but that had no impact on battery use.
    I am still on KitKat and have been postponing the update to Lollipop for the last month. Could be it?
    06-05-2015 04:24 PM
  4. Kelly Kearns's Avatar
    Used to be when I changed it to 100%, I didn't use it much it would still be at 100% and hour or two later. With my typical use, it would be down to maybe 40% to 50% after 24 hours, now it can't last 24 hours without fallig below 20. When it dropped from 70 to 40 overnight just sitting there. Six hours before this screenshot it was at about 70%
    Attachment 179964
    The pictures isn't showing up for me.
    06-05-2015 05:18 PM
  5. Lady Grinning Soul's Avatar
    fixed it. thank you.
    06-05-2015 05:40 PM
  6. Blacklac's Avatar
    Does that awake time mean something is keeping my CPU active when the screen is off?
    Pic below, need one more to post links...
    07-02-2015 11:43 AM
  7. Blacklac's Avatar
    07-02-2015 11:43 AM
  8. Lady Grinning Soul's Avatar
    I found that my battery life returned to normal after I had run the battery down to near single digits or lower a couple of times. It just started behaving normally again.
    Still on KitKat.
    07-03-2015 03:53 PM
  9. palanilopez12's Avatar
    Have you added any new apps? Mine is looking like this as well. In the middle of the night something will wake my phone and it'll stay awake for nearly the rest of the day. It's getting ridiculous since I haven't done anything different.
    07-04-2015 02:56 PM
  10. Jeff Jones9's Avatar
    I have a 10,000 mAh battery and had those similar issues. One thing i have done is discharge the battery to 5% , charge the phone with the power off all the way to 100%. Use the phone has you would normally the next day, let it drain to 5% again. ( it may drain quickly the second day. ) Repeat this process for two more days. Hopefully this will calibrate the battery and the phone to match. Please post results.
    07-06-2015 10:22 PM
  11. AlexMarie15's Avatar
    I took my phone of the charger last night before going to sleep figuring I'd lose maybe 20% as I annoyingly normally do in standby, but I woke up to a dead phone. This is getting ridiculous. Something kept it awake and I don't know what it was, but this phone shouldn't be running into this kind of trouble when my iPhone 5s could sit in standby for days.
    Attached Thumbnails Galaxy Note 4: Battery Life Concerns Check Here First-1436543683555.jpg
    07-10-2015 10:54 AM
  12. Marwan Gharib's Avatar
    For me, Lollipop just did not work for battery life, I simply reverted back to KitKat and now am back to rocking awesome battery life.
    07-16-2015 05:17 AM
  13. Blacklac's Avatar
    After a hard reset (didn't restore any backups) this hasn't changed. I still have a lot of awake time when the screen is off. I tried Greenify and hibernated any Apps I didn't want on and it helped a little, not much.
    Could it be from having WiFi always on? I wouldn't think so, but I can't explain it. I do know YouTube had a lot of CPU time when it wasn't being used.
    07-16-2015 10:09 AM
  14. Blacklac's Avatar
    Here it is now. I wiped my phone last night. It is quite a bit better, but not perfect, I guess. Screen on time appears to remain identical, ~4.5-5hrs.
    07-16-2015 10:12 AM
  15. TechNut79's Avatar
    I've had my phone for almost 9 months and always used the Adaptive Fast Charging. My battery will get down to 20% or 19% and then drop to 10% and below 5% very quickly and then shut off. Should I buy a new battery and only use the AFC when I really need it?
    2bblue and jayedandy like this.
    07-16-2015 07:18 PM
  16. james491225's Avatar
    Thank you!!!
    07-17-2015 02:03 AM
  17. lpcs1's Avatar
    I have the exact same problem ... I leave my GN4 with 60-70% and i often find the battery dead empty in the morning ... which has already led me to missing a few appointments.
    I looked into it and i realized that only 25% of the actual battery drainage appear in the power saving settings: meaning that 75% of whats causing the problem comes from an external source . Virus? Battery wear ? Galaxy Note 4: Battery Life Concerns Check Here First-screenshot_2015-07-20-17-44-11.jpg
    07-20-2015 10:57 AM
  18. andriod Themefordoid's Avatar
    07-22-2015 10:08 AM
  19. trac3rbull3t's Avatar
    There are battery saving apps available.... Do these actually work?
    07-23-2015 07:52 AM
  20. Dankees's Avatar
    What exactly did you do to fix your battery issues?
    07-23-2015 03:46 PM
  21. Dankees's Avatar
    How did you revert back?
    07-23-2015 03:49 PM
  22. jordyd's Avatar
    Google Now seems to be a large battery drain for me, especially overnight, so I've disabled it now.
    Sent from my Galaxy Note 4
    07-25-2015 04:07 PM
  23. Sidney160299's Avatar
    Turned location off and has been off for a week but google location service is still in the list of running applications? Worried it is what is causing bad battery life on my note 4? What are your thoughts
    07-25-2015 06:34 PM
  24. Dankees's Avatar
    Does the "OK Google" voice detection feature kill the battery?
    07-26-2015 12:07 AM
  25. Sidney160299's Avatar
    What do you guys reckon is keeping my phone awake? I know this is pretty good battery life but just out of curiosity I wanted to know. I have location off and always toggle wifi and data off and on when needed. These scree ****s were taken with a SOT of about 4hrs. Thanks
    Attached Thumbnails Galaxy Note 4: Battery Life Concerns Check Here First-1438262982164.jpg   Galaxy Note 4: Battery Life Concerns Check Here First-1438263002190.jpg
    07-30-2015 08:32 AM
233 ... 678910
  1. Replies: 20
    Last Post: 02-10-2015, 09:00 AM
  2. Verizon Galaxy Note 2: Ghost image at notification bar
    By jlost in forum Verizon Galaxy Note 2
    Last Post: 12-05-2014, 12:41 PM
  3. Will note 3 lollipop get ultra power saving mode?
    By MaLik Hadi in forum Ask a Question
    Last Post: 12-04-2014, 01:05 PM
  4. How do I find my pictures on my Galaxy S5?
    By Ozmandious in forum Samsung Galaxy S5
    Last Post: 12-04-2014, 09:03 AM
