02-03-2015 07:28 AM
38 12
tools
  1. Joe Nunya's Avatar
    The first few days with the Note 4 I was rather disappointed with battery life, in 2 days I had it on the charger 3X.
    One major battery hog was just one app called Accupedo which for some stupid reason will stay on and eat battery 24/7 even though I only need it for about an hour a day so I had to go into app manager and force stop it.
    But after stopping that one battery hog app and after a couple weeks now of the newness wearing off and the phone setting down I now usually get about 36 hours of battery.
    Right now I am at 53% battery left after almost exactly 24 hours with 3 hours and 48 minutes of screen on time.
    So pretty much I get a whole day which is acceptable especially since the fast charge is available and I have a 10,000ah portable battery to draw from if needed, plus I plan on buying the spare battery with charging case so I can carry a spare easily.
    That sound slike a much better solution that some 10,000ah battery and case that basically turns this into a Tablet in size which makes it unusable for me.
    tea lady 92 likes this.
    12-09-2014 10:54 AM
  2. tea lady 92's Avatar
    Oh, that sounds amazing!!
    I got my phone yesterday...and so fat it's disappointing me. Battery is not lasting at all. I can see it drop right before my eyes. Do you think I should wait around a bit?
    12-09-2014 12:27 PM
  3. bobxxz's Avatar
    IMO, you should stop looking at the battery percentage and just use the phone.. Plus you just got the phone and trust me I bet you were using the phone the whole time to set it up and playing with it.. Most note 4 battery seem to average 4-7 hours screen time based on what they are doing with the phone.. For me I average 5 hours and a half screen time before I start charging
    12-09-2014 01:07 PM
  4. Joe Nunya's Avatar
    Yep, just use it, get all the usual setting up the phone out of the way and wait about 2 weeks. It should slowly start getting a bit better.
    Unless you are an extremely heavy user you should get at least a full day out of the battery.
    On average I would say most will get about 36 hours.
    12-09-2014 01:44 PM
  5. chevyman29's Avatar
    Yes your not a heavy user so that makes sense but for heavy users games certain apps the screens on movies games your asking for horrible battery life!!! Remember energy cannot be lost but transformed all that electrical charge will dissipate sooner when you play games you know the back of your phone gets hot that's the energy being transformed into heat and heat will degrade things further
    Just because I don't use my phone in the same manner as you doesn't mean I'm not a heavy user. I routinely talk 3 to 4 hours and use 4 hours or more a day of screen time doing business related things.
    There is no phone that will hold up to high intensity gaming for hours on end.
    12-09-2014 02:58 PM
  6. tea lady 92's Avatar
    Thanks for that!! I will do that. See how it goes!! 😊
    12-09-2014 04:02 PM
  7. tea lady 92's Avatar
    Haha...yes, I was actually constantly using it...admiring the size....but yeah I've disabled the percentage thing because all I would do is count....90...89.. 87 haha...so yeah, advice is taken on board!
    So screen time is different to the length it lasts? I guess the power of the screen might drain it. I'll use it and wait around a bit ☺ thanks again!
    BTW - what does IMO mean? 😳
    12-09-2014 04:05 PM
  8. leerandall's Avatar
    IMO = in my opinion
    12-09-2014 05:43 PM
  9. leerandall's Avatar
    IMO = in my opinion
    12-09-2014 05:43 PM
  10. bobxxz's Avatar
    Yeah if you want to read the battery accurately, you should look at your screen time mostly. Screen time means you actually using the phone with the screen on.
    12-09-2014 05:48 PM
  11. varunaX's Avatar
    http://tapatalk.imageshack.com/v2/14...aa5645e7b3.jpg
    Myself lol and I have barely use my phone today
    Sent from my SM-N910V using Tapatalk
    can you post a screenshot of youre screen time for this day?
    12-10-2014 09:32 AM
  12. Closingracer's Avatar
    I can't since it was a week ago but it was between 30 mins to 45 mins that day
    12-10-2014 09:50 AM
  13. rocky28297's Avatar
    I know there's been a million and one post talking about battery life but seriously I'm starting to think mine may be going to crap.
    Just being on my phone for 30 min browsing the Web will take me from 100% down to 86% that's horrible!!
    What can I do....?
    And for some reason the android system is using 59% or my battery life...wtf?
    Uninstall the apps that u don't and see if it helps you out not. There must be an app eating your battery. And pls disable the bloatware as it does drains the battery.if uninstalling apps doesn't work then do a factory data reset and then install apps again one by one slowly and uninstall the last installed app if the phone's battery suddenly starts draining........
    I am sorry if a typed more but i have done lots of browsing and experiments regarding android's battery coz i have increased my screen on time from 2 hours to 3 hours by my research........ Reply whether it worked out not.....
    02-03-2015 07:28 AM
38 12
  1. Battery on new HTC One (M8) HK edition
    By slin9 in forum HTC One M8
    Last Post: 06-29-2015, 04:30 PM
  2. Battery percent stuck at 60.
    By eekfu in forum Samsung Galaxy Tab 3
    Last Post: 12-19-2014, 11:43 AM
  3. note 4 battery first days
    By Andrew Blackburn in forum Samsung Galaxy Note 4
    Last Post: 12-06-2014, 01:08 PM
  4. All of a sudden battery issues
    By markabele in forum Moto X (2014)
    Last Post: 12-05-2014, 10:57 PM
  5. Replies: 0
    Last Post: 12-05-2014, 10:39 AM
