12-09-2014 07:54 PM
26 12
tools
  1. Closingracer's Avatar
    Sent from my SM-N910V using Tapatalk
    12-06-2014 03:33 PM
  2. Rukbat's Avatar
    If it's downloading a lot of emails, that's normal. (If it's a new phone, it's going to be syncing for a long time if you get a lot of email.) But 32% drain in 5 hours, considering how hard GMail was running, isn't abnormal.
    Once GMail settles down, check that Awake line after charging and letting the phone sit overnight. It should be almost all white. If you get a lot of blue when the phone wasn't being used, something is keeping the phone from sleeping, and that eats battery power.
    earthwormjimx3 likes this.
    12-06-2014 03:47 PM
  3. Closingracer's Avatar
    From earlier
    12-06-2014 04:25 PM
  4. Closingracer's Avatar
    Seriously this is getting bad to worse pretty quickly. 8 hours and 27% and this is when I'm at work and didn't use the phone much
    12-06-2014 06:48 PM
  5. Closingracer's Avatar
    And squeaked in 10 hours
    12-06-2014 09:04 PM
  6. LaTuFu's Avatar
    Do you still have all of your messages sitting in your inbox? Or do you have them archived?
    If you have thousands of messages unarchived, it's probably trying to index all of them.
    12-06-2014 10:00 PM
  7. iOSConvert2k14's Avatar
    Exactly what I was gonna say. How many emails are in that inbox?
    12-06-2014 10:48 PM
  8. Closingracer's Avatar
    Ummmm a lot ? I get around 40 a day through 1 email client and have around 3-4 on gmail and he others get around 20-30 which I delete. Never had an issue with the native email client
    12-06-2014 11:31 PM
  9. Almeuit's Avatar
    I'd clear the cache and if that doesn't help... Sign out of your google account and sign in again. Something is cause it to hold the phone awake.
    12-07-2014 12:55 AM
  10. Almeuit's Avatar
    40 a day shouldn't do it. I am getting over 100 a day due to the forums. Something is causing the app to hold awake and that's why the drain is occurring.
    12-07-2014 12:56 AM
  11. Closingracer's Avatar
    Well that was for today ...I go between 40-150 at times
    12-07-2014 12:57 AM
  12. Almeuit's Avatar
    Regardless. That won't drain that much. Something is wrong where something is holding it awake.
    12-07-2014 01:02 AM
  13. dpham00's Avatar
    Something seems amiss. Seems it is keeping your phone awake. Today I got around 200 emails.
    In addition to the above, try uninstalling the updates to Gmail
    Sent from my Verizon Samsung Galaxy Note 4
    Attached Thumbnails Gmail draining battery?-uploadfromtaptalk1417933422662.jpg   Gmail draining battery?-uploadfromtaptalk1417933432204.jpg   Gmail draining battery?-uploadfromtaptalk1417933440971.jpg
    12-07-2014 01:24 AM
  14. dpham00's Avatar
    Yeah it also consume a bit battery because its a running app if you once opened or use it. So that make sure to totally close it on your application manager.
    This is not needed. I have never done this for Gmail
    Almeuit likes this.
    12-07-2014 01:27 AM
  15. LaTuFu's Avatar
    It's not so much the daily influx I was asking about.
    What do you do with emails once you have read them/dealt with them?
    Specifically to Gmail, since that is the app you are having issues with...do you archive messages you are finished with, or do you simply leave them hanging around in the inbox?
    If they are hanging around unarchived, I think your phone is trying to index them all.
    I would second the suggestions to clear cache and reboot, see if that clears up the problem.
    And if you have a lot of messages unarchived, you might want to consider dealing with that.
    12-07-2014 10:35 AM
  16. LaTuFu's Avatar
    That's not correct.
    Gmail works just fine on its own in the background. You do not need to manage it manually. It is not a significant resource drain if it is set up properly.
    12-07-2014 10:36 AM
  17. Closingracer's Avatar
    I honestly like the Gmail app but if I still have these issues since deleting the update and re-installing I'll just disable and use the native Samsung app
    12-07-2014 10:53 AM
  18. LaTuFu's Avatar
    Okay...that's still not answering the question...
    12-07-2014 11:07 AM
  19. Closingracer's Avatar
    What is archiving ....never used the Gmail app till a month ago. And if I have to do whatever it is to save battery I just won't use the app ...better apps elsewhere like the native one I am fine with
    12-07-2014 12:06 PM
  20. LaTuFu's Avatar
    Suit yourself. The Gmail app works as well as any other email app out there.
    If you want to use another app out there, it's personal preference. Not because there is anything "wrong" with the app.
    Archiving is a feature of gmail. (it is a feature of other platforms, too) It removes an email from the inbox when you are done with it, but it doesn't delete it. You can search for it at a later date if you need it.
    An important feature once you have accumulated a few thousand messages over the years.
    12-07-2014 12:23 PM
  21. Closingracer's Avatar
    I just save my email in my folders. And archiving isn't in Samsung native email client.
    Killed app, removed updates and cache and reinstalled seemed to do the trick
    12-07-2014 01:48 PM
  22. Closingracer's Avatar
    Much better today after basically station over with the app
    Attached Thumbnails Gmail draining battery?-uploadfromtaptalk1417988183618.jpg
    12-07-2014 04:36 PM
  23. George Nahorski's Avatar
    Download Bluemail and set to Push.
    12-08-2014 09:42 PM
  24. zabihjan's Avatar
    If this is about nexus 6, I found the solution. Download power toggles and control syncing manually. For some stupid reason Google has decided to remove power toggles from Lollipop. After downloading power toggles and controlling sync manually my battery 🔋 life has improved a lot. I have 3 Gmail accounts and 3 outlook accounts they were all syncing and killing my 🔋but now they sync when I want them to
    12-09-2014 03:50 AM
  25. Tablas's Avatar
    Closingracer, can you tell me please which application do you use to get these History graphics?
    12-09-2014 08:16 AM
26 12
  1. My Samsung Galaxy s5 battery drains quickly !!
    By n88enw in forum Samsung Galaxy S5
    Last Post: 09-19-2015, 06:28 PM
  2. Help needed in battery useage
    By philjory in forum Samsung Galaxy S5
    Last Post: 12-07-2014, 10:20 AM
  3. android wear battery widget on phone?
    By red.foxx15 in forum Android Wear
    Last Post: 12-06-2014, 11:34 PM
  4. On my Nexus 7 2013, why am I getting a Black Screen?
    By jason_sa in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-06-2014, 11:35 AM
  5. Android 5 versus Kitkat 4.4.2 battery life test
    By walterg1 in forum Android 5.0 Lollipop
    Last Post: 12-06-2014, 04:53 AM
