1. filo8818's Avatar
    Hello everyone,
    there is a way to access the S voice assistant by tapping twice or the home button or the headphone button even if my device is locked with fingerprints?
    Thanks
    12-07-2014 06:15 AM
  2. Bosbouer's Avatar
    A double, firm press on the home key does it for me. BUT I have not tried it with fingerprint Screenlock.
    12-07-2014 06:23 AM
  3. filo8818's Avatar
    But you have to set it somewhere?
    12-07-2014 06:44 AM
  4. Bosbouer's Avatar
    From the applications drawer open s voice. Then tap the 3 dots in the top r/hand corner. From options select open with home button
    12-07-2014 07:56 AM
  5. filo8818's Avatar
    Ya like this you se to open it up with the button and it s working great but not with looked screen...
    I guess is the only way and is not possible....
    12-07-2014 12:37 PM
  6. al3azim's Avatar
    Why don't you just use "Ok Google" from the lock screen. You can set that up in the Goog Search setting. This better than SVoice anyways.
    Sonnydigs likes this.
    12-07-2014 02:01 PM
  7. mty msi's Avatar
    OK Google wakes up my phone but doesn't do anything when the lockscreen is activated. I can't make a phone call or look up anything online so as far as I can tell the OK Google feature is useless when the fingerprint lockscreen is activated. And I have the Outgoing call conditions set to "make calls even while device is locked" but I can't make calls when its locked either with OK Google or manually dialing because there is no access to the phone dialer when the lockscreen is locked.
    Are you saying OK Google works the same on your phone when the screen is locked as it does when the screen is unlocked?
    12-07-2014 05:10 PM
  8. angel220's Avatar
    You can turn on s voice wake up from lock screen in s voice settings.
    12-07-2014 07:09 PM
  1. Where did the built-in flashlight disappear?
    By Idan Barir in forum Android 5.0 Lollipop
    Last Post: 09-20-2017, 05:41 PM
  2. Verizon note 4 cases
    By maaron1300 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 01-19-2015, 01:17 AM
  3. Why is my data not working?
    By Slashyou in forum Ask a Question
    Last Post: 12-07-2014, 01:51 PM
  4. Why is my battery dying so suddenly?
    By kaimu in forum Batteries
    Last Post: 12-07-2014, 07:07 AM
  5. I need to get back my browser from play store it keeps saying error 492
    By Kerichenkok3 in forum Samsung Galaxy S III Accessories
    Last Post: 12-07-2014, 06:08 AM
