1. carebearess's Avatar
    I just got a Note 4 last week. When I open the stock camera app, it takes about 20 seconds for it to focus on anything. Is this normal? It only happens when I open it after not being in use for about 30 minutes. If I keep opening the app, it is fine.
    I went back to T-Mobile and exchanged for a different phone, same thing. I've tried with stock and market camera app. Same thing. Just not sure if it's supposed to be this way or if something is wrong with my phone.
    12-08-2014 12:59 PM
  2. keyzlife's Avatar
    Its a defect with the camera itself. Ran into the same thing with my wife's white tmo version. Ordered the replacement phone from warehouse and it works perfect.
    sent from my Samsung GALAXY Note® 4
    12-08-2014 01:12 PM
  3. Sam Itani's Avatar
    Hello, I just bought a note 4 from some one and I realized I have the same problem.. I mean it works after 20 seconds like you said after I spam my finger on what I want it to focus... But it is very annoying.
    12-18-2014 05:49 PM
  4. keyzlife's Avatar
    I could tell it was a hardware problem when I would tap the end of the phone and it would focus.
    12-18-2014 09:58 PM
  5. ejohnnyk's Avatar
    My camera is fast and responsive. 20 seconds is not normal. It could, perhaps, be the SD card causing the problem.
    12-18-2014 11:55 PM
  6. Joe1967's Avatar
    Yah I just got my note 4 about 3 weeks ago. Has had the same issue with taking 30 seconds to focus the first time the app is opened. I switched from the SD card to internal memory and my problem has disappeared. So glad because I love the camera quality.
    01-23-2015 07:16 PM
  7. z06mike's Avatar
    First thing is to make sure you have taken the plastic off of the camera.
    01-23-2015 07:28 PM
  8. heathersimon's Avatar
    Yup, if you give the top of your phone a thwack and the camera focuses right away, send it in to be repaired or get a replacement. (Still on my List of Things to Do, but I just don't want to be without this otherwise glorious device for a week...)
    01-23-2015 10:15 PM
  9. zeroviper89's Avatar
    This is as per T-mobile!!
    Reset the Camera settings and retest.
    From the Home screen, open the Apps tray.
    Tap Camera.
    Tap the Settings icon.
    Tap Reset settings.
    Reboot the device into Safe Mode and retest. If the camera is able to focus while in Safe mode, a 3rd party app has been installed and will need to be uninstalled.
    If the above steps do not work contact customer care.
    It seems like it may be a hardware component, so an OTA may not present a fix, only a device exchange. If I end up with more information, I will be sure to share.
    Otherwise, please follow the steps, I definitely understand it may not be related to third parties, but for now, those are the steps we have to try, and if they don't work, feel free to contact us directly so we can reference the IMEI and explore any needed exchange options!
    If any new info comes up, I'll be back to share!
    Hot off the presses
    #note4nearsighted
    #note4focusgate
    EricH0ang likes this.
    02-19-2015 04:34 PM
  10. wookiee2cu's Avatar
    I had this issue on my AT&T phone. I reset the camera settings, didn't work. I did a factory reset and still didn't work. I went into the AT&T store and showed them what was going on (it took 11 full seconds before it would start to focus on everything) and the rep wanted to reset the camera settings and try it out for a few days. I explained I had already done that and then a factory reset so they offered to exchange it since I had only had it for 7 days. The exchange process took forever (not the reps fault, just all the hoops the system made them jump through) but all is good and my new Note 4 focuses within 1 second. If you are within your 14 days of purchase (depends on carrier) just take it in and exchange it.
    02-19-2015 05:30 PM
  11. natehoy's Avatar
    As others have said, this is not normal. I can hit the camera icon and by the time the screen appears (about a second or so), it's usually already focused and ready to go.
    I do have the occasional issue on macro shots with the focus being "indecisive" but specifically selecting a focus point clears that up in a hurry, usually.
    02-19-2015 05:48 PM
  12. COMMISSIONERHBK9's Avatar
    I'm still new to android but is the focus on the note 4 auto or u have to do something
    02-21-2015 08:42 PM
  13. EricH0ang's Avatar
    Thanks alot, that simply fixed the problem. I didnt even have to put it to safe mode, just reset settings.
    11-04-2016 12:07 AM
  1. What Device Should I get (Use Cases and What I'm looking for)
    By tplace 1976 in forum Android Wear / Wear OS
    Last Post: 04-06-2015, 07:56 PM
  2. Stuck Note 10.1
    By Melty Cat in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-07-2015, 12:41 PM
  3. Replies: 8
    Last Post: 12-09-2014, 08:55 PM
  4. Replies: 5
    Last Post: 12-08-2014, 05:08 PM
  5. Why isn't my settings button working?
    By mtlqrx in forum General Help and How To
    Last Post: 12-08-2014, 02:08 PM
