1. Prince1984's Avatar
    you know when you hold the note 4 with direct sun light on it, it gets extremely bright and you can see the screen very good...
    i want to have the possibility to make it that bright when i want and not just on sun light (cause when i'm not in direct sun light it also hard to see)
    i tried looking in setting but nothing there... i can put it on high bright but never like that brightens in sun light
    any idea what i can do?? maybe some tweak or app?
    thanks
    12-09-2014 06:50 AM
  2. LaTuFu's Avatar
    Thats probably a function that will require root.
    12-09-2014 08:20 AM
  3. Prince1984's Avatar
    and is there any root available then...?
    (any guide how to root the phone..?)
    12-09-2014 11:10 AM
  4. makie's Avatar
    Probably on xda forum.
    12-09-2014 04:06 PM
  5. treyzdayz's Avatar
    Which carrier is your note 4 on?
    12-09-2014 08:22 PM
  6. ejohnnyk's Avatar
    Here's an AC article about this issue...
    Here's how you make your Galaxy Note 4's display usable in direct sunlight | Android Central
    If you have Auto Brightness enabled... the Note 4 will turn SUPER BRIGHT in direct sunlight. BRIGHTER than the maximum manual setting. The ONLY way, apparently, to achieve this super bright setting is when Auto Brightness is enabled. It can not be achieved manually (without root, perhaps).
    12-10-2014 02:41 AM
  7. FFR's Avatar
    It would kill your battery life.
    Sent from my iPhone 6+ using Tapatalk
    12-10-2014 04:30 AM
  1. Replies: 3
    Last Post: 12-29-2014, 05:28 AM
  2. Replies: 1
    Last Post: 12-10-2014, 03:01 PM
  3. When will I get my $25?
    By Aravind Don in forum Ask a Question
    Last Post: 12-10-2014, 02:53 AM
  4. Replies: 1
    Last Post: 12-09-2014, 06:03 AM
  5. Replies: 0
    Last Post: 12-09-2014, 05:56 AM
