1. Coconut8469's Avatar
    Ya my problem is the phone freezes up. Had to restore the phone after a month of ownership. Is it an app, or operating system issue? By the way the restore did work for now...
    12-09-2014 07:33 PM
  2. NVNJ's Avatar
    From the get go or recently ?
    12-09-2014 07:37 PM
  3. SpookDroid's Avatar
    Are you doing anything specific when it freezes up? Mine only has a slight lag on the multitasking menu and a very apparent delay (sometimes a couple, sometimes up to 10 seconds) when trying to view the last picture taken directly from the camera, especially if I'm using the front facing one (watching the same image from the Gallery causes no delay). Other than than, never a hiccup or freeze up.
    12-09-2014 07:48 PM
  4. fantom305's Avatar
    Mine will freeze either when trying to make a phone call, or checking the email or trying to use any other app..... after a couple of seconds it reboots by itself and then it works fine ....until next time. Unfortunately there is not a set pattern, it just happens at random times and days....
    12-09-2014 09:58 PM
  5. Rmedy21's Avatar
    Must be an app that is causing the issue
    Amazing Verizon Galaxy Note 4
    12-11-2014 08:06 AM
  6. dpham00's Avatar
    I would suggest that you do a factory data reset, then don't install any apps to see if the problem goes away. If it does then slowly reinstall apps until you find the offending app.
    Sent from my Verizon Samsung Galaxy Note 4
    12-11-2014 09:53 AM
  7. SpookDroid's Avatar
    Or you can enter Safe Mode (which is basically booting up without letting any 3rd party apps to start) and see if it happens. Remember, in Safe Mode, 3rd party apps do no start on their own, but if you do open an app, it will then start and do what it usually does. It's a good way to pin-point an app that's misbehaving if you don't want to do a factory reset.
    https://www.google.com/url?sa=t&rct=...WlZ9M7xcqSRmrQ
    dpham00 likes this.
    12-11-2014 12:35 PM
  8. Coconut8469's Avatar
    Recently
    12-11-2014 01:43 PM
  9. Coconut8469's Avatar
    I'm texting mostly when I seems to freeze up the most. Sometimes running other apps. Oh especially in kid mode.
    12-11-2014 01:44 PM
  10. Coconut8469's Avatar
    Randomly for the most part also.
    12-11-2014 01:45 PM
  11. Coconut8469's Avatar
    That's what I did. Seems to have solved my issues.
    12-11-2014 01:45 PM
  12. Coconut8469's Avatar
    I will keep this suggestion in mind.
    12-11-2014 01:46 PM
  1. Replies: 1
    Last Post: 12-14-2014, 11:51 PM
  2. How do I get rid of auto backup folder
    By alexx1227 in forum Samsung Galaxy Note 2
    Last Post: 12-11-2014, 12:39 PM
  3. Replies: 2
    Last Post: 12-09-2014, 09:01 PM
  4. How do I connect to 802.1x EAP Samsung Galaxy S4 rooted VZW?
    By Pleasehelp1 in forum Samsung Galaxy S4
    Last Post: 12-09-2014, 07:31 PM
