1. RionDunn's Avatar
    Hello everyone,
    I have noticed a sudden battery drain on my note 4 the last couple days. I'm not sure that I'm using it more than often cause it's difficult to gauge that. However I have included a screen shot of my usage for the last few hours. Can anyone tell me of something looks out of whack here? I installed Hangouts and have been using that for a couple days now, but I'm not sure if that's causing the battery drain. I cannot see hangouts listed on my system usage. Let me know!
    12-12-2014 10:59 AM
  2. Jon Jackson's Avatar
    Looks about the same as mine....yesterday after 3.5 hours I was at 92%. Today at 3.5 hours I am at 80%. *shrugs* Who knows......it's always a surprise. I could get home tonight and it's 70 something percent or maybe it will be in the 40's.
    12-12-2014 11:05 AM
  3. SpookDroid's Avatar
    I don't see anything out of the ordinary, really... except maybe the crappy reception. That can drain your battery quite fast.
    12-12-2014 11:12 AM
  4. SpookDroid's Avatar
    Maybe Google Play Services got updated? If so, you could try clearing cache for that. Sometimes it acts up after an update...
    12-12-2014 11:13 AM
  5. Jon Jackson's Avatar
    It's funny my battery was better yesterday and last night I disable a lot of the google bloatware and its worse today. Go figure.
    12-12-2014 11:18 AM
  6. Telespielstube's Avatar
    Google bloat ware??
    Sent from my iPhone using Tapatalk
    12-12-2014 11:34 AM
  7. Jon Jackson's Avatar
    Google bloat ware??
    the music, google +, books etc etc....
    12-12-2014 11:35 AM
  8. LegalAmerican's Avatar
    Mine's been doing the same thing. More often than not, i'll have 80% or more when I leave work to go home. But today and another day last week, it goes down so fast for no reason. The only thing I can guess is that something is waking it a ton (which it is according to the stats) but it's odd cause it wakes a lot every day, but only some days does the battery suck.
    12-12-2014 11:53 AM
  9. Almeuit's Avatar
    I would have to see your screen on time to really judge it.
    12-12-2014 02:53 PM
  10. Jon Jackson's Avatar
    For me 53 minutes screen time and I am down to 60% in 7 hours.....BUT yesterday in 7 hours and I was around 85%. Android can be weird like that.
    12-12-2014 02:55 PM
  11. LaTuFu's Avatar
    For the moment, I'm going to discount your experience only because you're still within the first few days of having the device. The battery performance during that period is usually lower than it will be later on.
    12-12-2014 03:46 PM
  12. LegalAmerican's Avatar
    I'm down to 80% with 7 minutes of screen on time, and it's been off the charger for 8 h 13 m 21 s. I should be over 90% easy with stats like that if it was a normal day.
    12-12-2014 04:01 PM
  13. LaTuFu's Avatar
    Yeah, hopefully that is just an indication that your phone is reindexing after that update, and not performing worse as a result of it.
    12-12-2014 04:03 PM
  14. RionDunn's Avatar
    Attached Thumbnails Notice random battery drain-1418428110330.jpg   Notice random battery drain-1418428121370.jpg
    12-12-2014 05:48 PM
  15. mlbyanks11's Avatar
    My battery life is absolute garbage and can't seem to figure out why the hell I can't even get a day out of mine
    Attached Thumbnails Notice random battery drain-screenshot_2014-12-12-19-11-17.jpg   Notice random battery drain-screenshot_2014-12-12-19-10-44.jpg   Notice random battery drain-screenshot_2014-12-12-19-10-37.jpg
    12-12-2014 06:13 PM
  16. SpookDroid's Avatar
    You have half an hour of screen on time, with only one hour off the charger and at nearly 90% battery left? I wouldn't say that's bad at all!
    12-12-2014 06:15 PM
  17. mlbyanks11's Avatar
    Nah that's garbage....the battery on this phone is awful...I don't get a day out of it which I just said...drains too fast.... Even when I'm not using it
    12-12-2014 06:40 PM
  18. RionDunn's Avatar
    I would suggest taking all the garbage apps off your phone. That'll help you tons. The anti virus, I'm assuming is the shield emblem, and the battery app. I thought these apps were awesome to have but they just made my device run harder and die sooner. I do not have anti viral programs, I only run Samsung battery info, the native battery info that is within settings and I let Android do the rest of the work. Try it out for a little bit and see how it works. You'll have to give it a few weeks to a month I would think to really see the difference.
    12-13-2014 12:55 AM
  19. RionDunn's Avatar
    Like I said, you're garbage apps that are running constantly in the back ground. The ones that show at the top of your notification panel.
    12-13-2014 12:57 AM
  20. LaTuFu's Avatar
    Turn off all of the garbage apps you have running. Whatever those shields are (lookout?) and the two battery managers you seem to have. Between those, your phone is always awake. You only want your phone awake when you're actually using it.
    Those useless apps are what are killing your battery.
    ray sital likes this.
    12-13-2014 04:58 AM
  21. ray sital's Avatar
    http://tapatalk.imageshack.com/v2/14...5b5f7c4680.jpg
    Way to make great use of your note.
    SpookDroid likes this.
    12-13-2014 08:03 AM
  22. Brandwin's Avatar
    I lost 20% while sleeping...
    12-13-2014 08:15 AM
  23. dpham00's Avatar
    It is probably only one or two offending apps that is causing the phone to always be awake. He can use gsam to set which apps they are. Yeah removing the apps would get even better battery life, but removing the offending app would help a bit to begin with.
    Sent from my Verizon Samsung Galaxy Note 4
    Attached Thumbnails Notice random battery drain-uploadfromtaptalk1418481730302.jpg
    12-13-2014 08:43 AM
  24. RionDunn's Avatar
    Lol that's what I'm saying!!!!
    12-13-2014 09:22 AM
  1. Best Spare Universal battery charger
    By ilordvader in forum Samsung Galaxy Note Edge
    Last Post: 02-23-2015, 07:33 PM
  2. Note Edge random notification sound?
    By iGalione in forum Samsung Galaxy Note Edge
    Last Post: 12-16-2014, 01:42 AM
  3. Why is my S4 battery charging slowly?
    By Winston P in forum Batteries
    Last Post: 12-14-2014, 02:16 AM
  4. Universal battery charger
    By ilordvader in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-12-2014, 06:17 AM
