1. Jon Jackson's Avatar
    Our office bought note 4s. All of theirs works on off the shelf chargers. Mine won't. Screen goes off and on making the Ding Ding sounds like it's a bad connection. Anyone know why?
    12-12-2014 07:06 PM
  2. SpookDroid's Avatar
    That's odd... mine works with any charger, too. Adaptive Fast Charging works only with the supplied charger, but 'normal' charging should work with any microUSB one. Maybe you got a bad unit?
    12-12-2014 07:13 PM
  3. Jon Jackson's Avatar
    It worked on different chargers for the first few days then today tried two different ones and it won't work. Like it's not quite making a good connection. The one it came with works but I see no difference between the two. If I warped or damaged the female part I don't see why the stock would work
    12-12-2014 07:32 PM
  4. harryhoudini66's Avatar
    What are you connecting the cable to i.e. PC, outlet, other charging device such as a pad?
    12-13-2014 08:55 PM
  1. Replies: 7
    Last Post: 08-15-2016, 07:47 PM
  2. Replies: 4
    Last Post: 02-22-2015, 02:28 PM
  3. Phone in charger keeps chiming and screen comes on and off over and over
    By Jon Jackson in forum Samsung Galaxy Note 4
    Last Post: 12-16-2014, 10:19 AM
  4. Why does my Galaxy S5 have a black unresponsive screen?
    By Matthew Krizman in forum Samsung Galaxy S5
    Last Post: 12-15-2014, 06:25 AM
  5. What's up with Currents?
    By Alex Wetzel in forum Android 5.0 Lollipop
    Last Post: 12-14-2014, 03:28 PM
