note 4 faster than nexus 6 !!
makie
320
Could you post a screenshot of that "Screen" of the SOT on iOS 8? All I see is usage. I would really like to see the SOT like you do on Android when you select "Screen."
I did trade my iPhone 6 with the note 4 I have now. Will check for you guys on my sister her ip5. Just not sure if she's on 8.1 or 8.2 yett
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
When you go to battery usage there is an option called "screen" like on android, there you will see the exact time😉
On Android, yes. My refute was of your claim that ios shows SOT, which it doesn't.
Sent from my Verizon Samsung Galaxy Note 4
makie
320
My sister is on iOS 7 which just shows battery usage as in general. I seriously could push on "screen" and see my screen usage (exact time). This was on iOS 8.1/2
Edit: been looking though some forums and I'm not sure but can't find it anywhere, Gues you are right then. Probably seen usage or something..
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
There is not a screen time on iOS. Maybe in another app but not the default one. Please see my 6+ screenshot below. On Android you can tap screen and see you had the screen on for 4 hours or whatever. iOS does not tell you the time. The "usage" is not how long the screen has been on.
unirockers
