12-15-2014 02:47 PM
27 12
tools
  1. Seremedy's Avatar
    Phonebuff on youtube made a video of the note 4 vs the nexus 6 and iphone 6. In the app opening test the note 4 came out on top in opening apps the fastest compared to the iphone 6 and even the stock android nexus 6.
    Posted via my powerhouse of a note 4
    12-14-2014 12:50 AM
  2. Almeuit's Avatar
    Yep it ain't bad .
    12-14-2014 01:13 AM
  3. naira1's Avatar
    At the end the nexus 6 was still faster than the note 4 albeit with just under 2 seconds. If the note 4 with TW can hold its own against vanilla android then am gamed. I love this phone and TW is much better than what I have in SGS4.
    Sent from my SM-N910C using Tapatalk
    12-14-2014 04:43 AM
  4. makie's Avatar
    I don't always want to have the fastest phone even tho I would like that. I need to find a balance between speed, design and batterylife. Iphone 6 beats both other phones in SOT ( did own a ip6 before the note 4 ) my iPhone 6 could get 10h SOT, the nexus 6 and the note 4 can get around 4-6h. This actually kinda worries me, since I don't want to stress out (like I do) when I see my battery hit 60% at the half of the day since I play even more with my phone at the evenings😉
    12-14-2014 05:52 AM
  5. naira1's Avatar
    Don't know about you but I get 6-7 hours SOT on my note 4. That's plenty enough for me.
    Comparing the 2k screen of the note 4 to an iPhone 1080P not to forget the screen size difference. Am plenty satisfied and it's a no brainer for me who the real winner is. Just my opinion though.
    makie likes this.
    12-14-2014 06:02 AM
  6. makie's Avatar
    Iphone 6 has 720P lol! But also a way smaller battery! 6-7h sot, than you have to run the battery totally flat! I've disabled so many samsung apps to safe some battery and in my last 7 days I had 6h sot just 1 time. Had to be on wifi the whole day... I know the 2k resolution eats up battery, was the same on my G3 even tho I got 7h sot there.. I wish this phone was a bit more power friendly, but that's also duo to TW.
    Ps. How do you have your brightness ?
    12-14-2014 06:10 AM
  7. Seremedy's Avatar
    I dont really care if it was faster by 2 seconds at the end because the note 4 killed the nexus 6 at app opening speed. It just touchwiz that isnt resource friendly which made it reload apps furing the multitasking part compared to the nexus 6 which had a ton of free memory left so therefore it didnt have to reload apps. Day to day usage the note 4 is faster than the nexus 6 which i am happy about
    12-14-2014 10:11 AM
  8. dpham00's Avatar
    How are you determining SOT on the iPhone 6? IPhones by default don't show SOT. They do show usage which is whenever the cpu is used, regardless of whether the screen is on or off. In my usage, the 6 plus got about 10-20% better SOT. the 6 is supposed to get less battery life than 6 plus so I just find it questionable that you are getting a huge amount more SOT on the 6 over the Nexus 6 and Note 4.
    Sent from my Verizon Samsung Galaxy Note 4
    12-14-2014 05:16 PM
  9. makie's Avatar
    They did show SOT. Been looking on that every day since I do this with every phone
    12-14-2014 05:56 PM
  10. bobxxz's Avatar
    IMO, I believe battery on the 6 plus should be better than note 4 due to the screen and iOS and lack of customization. Note 4 you can do so much more and the quad HD screen kills battery faster.
    12-14-2014 05:57 PM
  11. Almeuit's Avatar
    Just FYI if you're getting the SOT for iPhone from the usage part of the battery screen that is not SOT. iPhone doesn't natively show SOT like Android.
    12-14-2014 07:00 PM
  12. makie's Avatar
    It shows your screen usage just like on android😉
    Attached Thumbnails note 4 faster than nexus 6 !!-screenshot_2014-12-15-01-17-33.jpg
    12-14-2014 07:18 PM
  13. Almeuit's Avatar
    Usage for iOS does not mean SOT is what I meant ... Usage can be the phone being idle and updating or receiving push. It is NOT screen on time. Either is Androids really .. Androids you have to tap screen to see the time. The usage can vary due to background tasks.
    12-14-2014 08:07 PM
  14. dpham00's Avatar
    Per apple:
    " View Usage to see the amount of time your iOS device has been awake and in use since the last full charge. The device is awake if you’re on a call, using apps, listening to music, browsing the web, or sending and receiving email, or if an app refreshes in the background. View Standby to see the amount of time the device has been turned on since its last full charge, including the time the device has been asleep."
    http://support.apple.com/en-us/HT201264
    This is in line with what I saw when using the iPhone 6 plus. I had 12 hours usage but actual SOT was definitely less
    Almeuit likes this.
    12-14-2014 09:03 PM
  15. dpham00's Avatar
    If you want to test use the phone for one hour straight and see how much the phone dropped during that time. It might be 10%,but it might also be more.
    Doing that test on the 6 plus used 12% ;note 4 14%. Both doing similar tasks,email Tapatalk, chrome, hangouts
    12-14-2014 09:09 PM
  16. naira1's Avatar
    Edit... Thanks Makie for the correction on iPhone 6 resolution.
    makie likes this.
    12-14-2014 11:20 PM
  17. jairusz's Avatar
    How many times are you going to experience the app opening speed unless you constantly restart your device. Sure my Note 4 may open apps faster but for my most frequently used apps my Nexus 6 smoothly transitions from one app to the next while on my Note it will lag when I go to the recent app menu, then stall before I go to the next app. At times I won't even be able to go where I left off since TouchWiz will boot some of my apps off the RAM since it's almost always near the max while my Nexus barely uses 1-1.5GB of RAM(including system apps). It will have to reopen the app and I have to find where I left off again. There is lag on the Nexus 6 but it rarely happens while I find it to be frequent on the Note 4.
    12-15-2014 12:33 AM
  18. makie's Avatar
    Per apple:
    When you go to battery usage there is an option called "screen" like on android, there you will see the exact time😉
    12-15-2014 05:10 AM
  19. trippymanni's Avatar
    I was wondering if you had Edge or the original note 4. I believe the Edge version is slightly slower?
    12-15-2014 05:58 AM
  20. Bishop_99's Avatar
    Could you post a screenshot of that "Screen" of the SOT on iOS 8? All I see is usage. I would really like to see the SOT like you do on Android when you select "Screen."
    12-15-2014 08:02 AM
  21. makie's Avatar
    I did trade my iPhone 6 with the note 4 I have now. Will check for you guys on my sister her ip5. Just not sure if she's on 8.1 or 8.2 yett
    12-15-2014 08:22 AM
  22. Bishop_99's Avatar
    Thanks!
    12-15-2014 08:23 AM
  23. dpham00's Avatar
    On Android, yes. My refute was of your claim that ios shows SOT, which it doesn't.
    12-15-2014 08:48 AM
  24. makie's Avatar
    My sister is on iOS 7 which just shows battery usage as in general. I seriously could push on "screen" and see my screen usage (exact time). This was on iOS 8.1/2
    Edit: been looking though some forums and I'm not sure but can't find it anywhere, Gues you are right then. Probably seen usage or something..
    12-15-2014 11:42 AM
  25. Almeuit's Avatar
    There is not a screen time on iOS. Maybe in another app but not the default one. Please see my 6+ screenshot below. On Android you can tap screen and see you had the screen on for 4 hours or whatever. iOS does not tell you the time. The "usage" is not how long the screen has been on.
    dpham00 likes this.
    12-15-2014 12:00 PM
27 12
  1. Replies: 8
    Last Post: 02-09-2015, 05:12 AM
  2. Nexus 6 - When will it be on sale (VZW)?
    By vegasdroid in forum Google Nexus 6
    Last Post: 01-01-2015, 12:16 PM
  3. Note 4 to TV
    By smoothrunnings in forum Samsung Galaxy Note 4
    Last Post: 12-18-2014, 01:11 AM
  4. Sprint Note 4 update
    By MannyZ28 in forum Samsung Galaxy Note 4
    Last Post: 12-14-2014, 10:30 PM
  5. What is the difference between Notes and Memos?
    By NZhadds in forum Samsung Galaxy S5
    Last Post: 12-13-2014, 08:21 PM
