Catch the unveiling of the Huawei Mate40 series on October 22
  1. trucksmoveamerica#AC's Avatar
    Below is a picture of the inside of my s charging back cover from Samsung. I have numbered each item, I'm curious as to which one is doing the wireless charging? The cover that came with the phone has nothing inside the cover.
    I'm having issues with it charging. I've tried the Samsung wireless charger that came with my s4, and a tylt charger. I'll wake up at night with the screen flashing from clock to home screen. I'm using gentle alarm and trying another alarm/night clock app but it's looking to do the same thing. Seems to get the tylt to work the best, I have to put on side and the number 2 on picture is almost off the charger which makes number one all the way off.
    Anyone else having issues? Next step is having Samsung replace the back. I'm not rooted, and I'm not using any task killers, don't know about the stock, never missed with it. Any ideas??
    12-15-2014 06:01 PM
  2. SpookDroid's Avatar
    I'm not sure exactly but 1 and 2 are definitely not it... 3 seems more likely to hold the coil which is what actually makes the charging possible. You might just need to align it properly... I know that on my Moto360 if I don't align it just right, the coil won't charge.
    PS: You own a Note 5? Cool! Shouldn't you keep that a secret though? :P (I'm joking, BTW... I'm assuming it was a typo).
    12-15-2014 06:05 PM
  3. trucksmoveamerica#AC's Avatar
    Thanks guys. I tried editing the title, didn't see where I did that if possible. Lol
    12-15-2014 09:51 PM
  4. dpham00's Avatar
    http://tapatalk.imageshack.com/v2/14...83c69a0c56.jpg
    None of those are the charging coil you can see it here. It is the oval copper coil
    Sent from my Verizon Samsung Galaxy Note 4
    Attached Thumbnails Issues with the wireless charging Note 4-uploadfromtaptalk1418752707900.jpg
    12-16-2014 11:58 AM
  5. SpookDroid's Avatar
    So the coil is smack in the middle of all those marked points haha. Cool, then as long as you center the phone it SHOULD work.
    12-16-2014 12:03 PM
  1. Apparent BlueTooth Issue
    By tem#AC in forum Samsung Galaxy S4
    Last Post: 01-09-2015, 06:44 AM
  2. How do I reset my Galaxy S4 with my computer ( NO ACCESS TO PHONE)?
    By jordanwills00 in forum Samsung Galaxy S4
    Last Post: 12-16-2014, 01:13 AM
  3. Can anyone connect the Turbo to Win. 8.1 x64 over ADB?
    By NoahForeman in forum Motorola Droid Turbo
    Last Post: 12-15-2014, 08:33 PM
  4. Replies: 3
    Last Post: 12-15-2014, 06:26 PM
  5. Replies: 0
    Last Post: 12-15-2014, 02:52 PM
