1. zaydabarber's Avatar
    Note 3 to note 4
    At&t note 3 & Gear 2
    12-16-2014 02:42 PM
  2. iGalione's Avatar
    I came from the Note 1, to the 2, to the 3, to the 4... someone keeps knocking on my door... ok, let me stop
    And each year it's a subtle yet needed upgrade:
    for the 4, it included, a crisper and sharper QWHD screen, better than 1080p and just bright as can be
    snappier performance than that of the note 3, by leaps, and you've noticed the instance with the better camera.
    it's more of a premium build, the s-pen is more responsive and better at recognizing hand writing... I mean it's a great update, and to make matters worse, I just recently got the note edge as well... the 4 is definitely better, but the edge has some getting used to.
    12-16-2014 04:19 PM
  3. zaydabarber's Avatar
    Is it worth the upgrade
    12-16-2014 05:36 PM
  4. crxx's Avatar
    The fast charging alone made it worth it to me... and that's just the start
    Da Note 4
    12-17-2014 05:55 AM
  5. dpham00's Avatar
    My thoughts on the Verizon Note 4 advantages over Verizon Note 3:
    -Significantly better battery life
    -Significantly better radio, especially in lower signal areas.
    -Runs substantially cooler
    -Charges significantly faster with adaptive charging.
    -Significantly easier to read outdoors
    -Camera is a MAJOR improvement in low light/motion shots. Note 4 has OIS.
    -Added fingerprint scanner (can be a bit finicky to use)
    -Added Heartrate monitor
    -Usage of Google "always listening" even when screen is off. Note 3 only had S-Voice always listening
    Minor points:
    -Added aluminum frame
    -QHD
    Cons:
    -Marginally heavier (I didn't really notice it)
    -No USB 3.0 (slower transfer speeds)
    -A hair taller (I didn't really notice it)
    -Speaker on the back
    Sent from my Verizon Samsung Galaxy Note 4
    iGalione and zaydabarber like this.
    12-17-2014 11:54 AM
  1. Replies: 3
    Last Post: 10-13-2016, 10:46 PM
  2. The Sprint Cup is no more — after 2016.
    By VW Maverick in forum Sprint
    Last Post: 01-07-2015, 01:28 PM
  3. "Wifi Disconnected. Please sign in again to network"
    By Moltres_rider in forum Samsung Galaxy S4
    Last Post: 12-16-2014, 04:47 PM
  4. Replies: 1
    Last Post: 12-16-2014, 03:04 PM
  5. Replies: 0
    Last Post: 12-16-2014, 01:27 PM
